2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Paddle shift install??
      04-22-2016, 03:14 PM   #1
phillipoga
phillipoga's Avatar
12
Drives: 2013 535i xDrive M-Sport
Can I somehow install paddle shifters on my F10 535i Msport? I don't have the sport trans but I have the manual shifting option, just want to be able to do it with paddles. Thx
      04-22-2016, 06:08 PM   #2
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Just Don't I have Paddle shift I never use them.
you better off getting nice diffuser or front lip
      04-22-2016, 07:23 PM   #3
Short answer..... Yes. It will take some and possibly an airbag; depending on the wheel you have. I posted my experience here somewhere.
      04-28-2016, 09:31 PM   #4
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Yes, you need to retrofit the steering wheel with correct wiring and paddle shifter, then lastly code the car to enable 2TB SAT option.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024"
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      04-28-2016, 10:29 PM   #5
Mine needed no wiring. The wheel was a direct fit. I did have to transplant my airbag into the new cover as the airbag that came with the wheel as a single-stage European model.
      04-29-2016, 05:52 PM   #6
Quicksilv3r
Quicksilv3r's Avatar
Drives: 2013 BMW 535i M-Sport
This. The paddles are pointless.
-WJV
      05-03-2016, 07:05 AM   #7
MasterC17
Drives: 2015 BMW M3
I'm pretty sure the OP was not looking for people's personal opinions on how useful paddle shifters are. I, for one, use them constantly.
Regardless, the retrofit is easy. A paddle shifter steering wheel is a direct swap on the F10. You do not need any additional wiring. You may need a different airbag depending on your current steering wheel.
Finally, you need to code the car as follows:
Re-Code for Sports Automatic Transmission:
Change FA (VO) to Remove 205 from VO & Add 2TB to VO
VO Code EGS, ICM, & KOMBI
Read FA(VO)Activate FA(VO)Read SVTRight-Click ECU & Select Code
VO Code ICM
VO Code KOMBI
SZL Module:
Enable Paddle Shifters (for Retrofits)
3000 Lenkrad_Schaltpaddles set to: aktiv
NOTE: Lenkrad_Schaltpaddles may also be named Variantencodierung_2_2_1
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
KClemente104.50
      05-04-2016, 04:05 PM   #8
cipher5
cipher5's Avatar
Drives: 2020 Donington Grey X3M Comp
If you want M6 paddles let me know, I have the plastic cutout plate for said paddles. That is if you have an Msport wheel.
