2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Steering wheel noise
      11-20-2013, 07:38 PM   #1
ajandhek
Drives: none
I have a noise comin from the car...if the steering wheel is in straight or neutral and I move it left to right real quick I'm getting a tapping noise or clicking.. it happens if car is on or off...sounds can be heard from inside and outside of car and sounds like it's comin from the steering column behind the engine any ideas?
      11-21-2013, 09:58 AM   #2
valcor535
valcor535's Avatar
Drives: 2011 535I X-Drive
I had the same on my late 2011 535ix... BMW replaced the steering shaft and steering gearbox, the sound or clunk noise has been reduced but still there; mine only does it when the steering is on the center position with the engine running or not, if you move the steering wheel left or right and try to replicate the clunk noise will not do it... weird...
      11-21-2013, 08:40 PM   #3
ajandhek
Drives: none
Thank you
      12-11-2013, 10:53 PM   #4
Lazz818
Drives: f10 535i
I have a sound coming from my f10 as well. It has xdrive with 26,000 miles on it. My noise is more of a squeaking noise when the wheel is turned to the left or the right when making turns. Does this sound like what you are describing? Or is it just normal friction?
      12-12-2013, 08:42 AM   #5
mcadori
Drives: 2014 535d Xdrive
The last time...
I had a clicking like you describe, it was in a Chevrolet Pickup (1995) and it was the upper steering column bearing, just beneath the steering wheel. Maybe that's it?
      12-12-2013, 11:06 PM   #6
Lazz818
Drives: f10 535i
Perhaps, thanks for the info. If it gets to the point where i need to get it looked at i will update with the cause.
      12-13-2013, 10:08 AM   #7
bkM3
Drives: 06 M3 Vert 6MT Carbon/Black
i had that sound then heard a crack when i was making a turn and the all the functions on the steering wheel went dead except for the steering itself. (heated wheel, horn,radio functions , airbag malfunction.) turned out the slip ring was defective and it cracked but was fully covered under warranty
