2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Marketplace Owner's Marketplace - F10/F11 Classifieds F10 Pre-LCI MSport Heated Steering Wheel w/ Airbag
      06-16-2016, 04:38 PM   #1
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
Sold
Or Best Offer
Shipping Costs Included
✓ Will Ship
Includes airbag, and all applicable wiring in the hub to the heater and radio controls.
Was removed from a 2011 550i and briefly installed in my 14 535i until I could put together my LCI wheel setup.
Cosmetically its in good overall shape, the leather has a few scratches from normal use but nothing heinous. Just typical wear being 5yrs old. Leather is soft and still has the original matte finish, not all shiny with hand oils....
Planning on removing this weekend to install my new LCI setup, so shipping will be Monday 6/20 at the earliest.
      06-19-2016, 05:04 PM   #2
Terry Bozeman
Drives: 2012 535i
In Georgia and have a 2012 535 with the base skinny wheel and no heat. Will this one work?
      06-19-2016, 05:47 PM   #3
Stück
Stück's Avatar
It will yes, it is a 5 minute direct swap if you're not concerned about getting the heater in the wheel working.
If you do want heat.... Does your car have lane change/departure warning? (your wheel would vibrate when you drift out of the lane) If so it will be plug and play as the connector in your SZL is already populated, and it will work with the addition of the heater switch next to the column adjustment switch which I will include at no additional charge.
If you don't have lane change/departure warning you'll also need the SZL cluster (the clock spring assembly) which again... I will supply if needed at no extra charge.
Oh and the heater function will need to be coded to the SZL_LWS.
This wheel does not have lane change/departure warning so you would have to migrate the vibration motor to it if you wanted to retain that.
      06-20-2016, 09:31 AM   #4
Terry Bozeman
Drives: 2012 535i
I do not have the change/departure warning included in my vehicle. I also do not have heat but would be interested in the heat function if it can be installed by my tech.
Will the SZL cluster (the clock spring assembly) you supply work and what about the heater switch I currently don't have? Not a deal breaker if the heat does not work.
      06-20-2016, 10:27 AM   #5
Stück
Stück's Avatar
I can include the heated column switch and the heated SZL with the wheel at no extra charge. Easy to install when the wheel is off anyway. You'll may or may not need to code the SZL but safe bet to assume you will anyway.
It's an easy enough retrofit there is no reason not to get it working, heated wheel in the winter is really nice.
      06-20-2016, 01:38 PM   #6
Terry Bozeman
Drives: 2012 535i
I am very interested. Checking once more with my tech, have someone in Atlanta you would recommend to install? Also, new to this site so how do you accept payment and is $375 acceptable to you?
      06-20-2016, 02:07 PM   #7
Stück
Stück's Avatar
I'll send you a PM.
