2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Messages option missing
      03-21-2012, 07:11 PM   #23
psyxologos
Drives: E46 330 ci SE, F11 530d SE
Originally Posted by premiertuning View Post
I've tried resetting the IDrive system (hold down Mute for 30 seconds) and that doesn't work either.
I wanted to do this but I could not find a mute button. Where is this?
Also, how can I get to the menu where 'Telephone' and 'Additional telephone' shows? I cannot find that either. What firmware do your cars run? Mine is supposed to be the latest, only out a few days (as I just took delivery of the F11 as an approved used I got them to throw this in the deal).
      03-21-2012, 07:14 PM   #24
psyxologos
Originally Posted by xenon View Post
Do an over-the-air software update. I did this the other week and it makes the media (iPod touch) work better. Can't do any harm.
I did this and nothing changed. If I understand well what you meant... I went to the settings menu and the last item on the list said update. I pressed this and connected to BMW services (or something to that effect).
I think it is my 158 contacts that are doing this. Funny enough, my 2005 E46 (330 ci SE) has no problem at all with my phone. I just cannot not read messages but that is to do with the phone compatibility. Deither does my wife's phone in our 330...
      03-22-2012, 02:28 AM   #25
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
I've got more than 158 so I don't know if that was it. Did you actually update the software? My car is a April 2011 build and there were two updates available which took about 12 minutes to download. You have to have the engine running but be stationary during that time.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      03-22-2012, 05:19 AM   #26
psyxologos
Thanks for that. What I did was chose the only 'update' option available in the whole menu. when I chose this the car connected to 'BMW services' or something like that and after a while I got a message that the update was completed. The whole thing lasted 2-3 minutes and the engine was off. I will try again with the engine running, but as I said, the car has the latest com box update done at the dealership on Monday before I took delivery of the car. They said that the update is the latest and was released this month. If it not much trouble, can you take a screenshot of the screen that I need to get to in order to execute the over the air update? That way I know I am in the right place...
As for the number of contacts, I do not know. As my addressbook is loaded as normal when I first pair the phone but disappears afterwards, I am at a loss as to what is going on. My wife's phone is identical to mine, with the same software, everything the same. Only the number of contacts differers. I have now brought my contacts down to 123 so I will check again later and see...
      03-22-2012, 05:29 AM   #27
xenon
xenon's Avatar
England
1397
See here:
http://www.e90post.com/forums/showthread.php?t=661335
Ian
      03-22-2012, 05:48 AM   #28
psyxologos
Thanks. I will have a go at it later!
      03-22-2012, 05:50 AM   #29
eskdale
Drives: 520d M Sport Touring F11
Its the volume control - Press to Mute and Hold for 30s to reset CIC
      03-22-2012, 05:55 AM   #30
eskdale
My car was built Jan 2012 but it still didn't have the latest Bluetooth software installed at the factory even though it was released before my car was built.
Mine failed to update 3 times when I tried the over the air update but it did work fine from a USB stick.
I'm on 3.5.4 and have 511 contacts so it shouldn't be an issue with 154 contacts
      03-22-2012, 06:17 AM   #31
psyxologos
Can you please give me the link for the download? I went to the Bmw owners section in the bmw website but was not sure where to look. Thanks again.
      03-22-2012, 06:24 AM   #32
eskdale
Bluetooth update
      03-22-2012, 08:14 AM   #33
psyxologos
Many thanks. I will try it and let you know.
      03-22-2012, 08:21 AM   #34
psyxologos
Just to make it clear, is this plug and play? Just dock the stick in the USB port in the central console? There is another USB port in the glove compartment. Are the both ok or do I have to use a specific one? Many thanks again.
      03-22-2012, 08:23 AM   #35
xenon
xenon's Avatar
England
1397
Use armrest then go to software update and choose USB.
Ian
      03-22-2012, 09:12 AM   #36
eskdale
I used the Glove box one and that definitely worked
      03-22-2012, 09:17 AM   #37
psyxologos
Thanks. Unfortunately nothing seems to work. Update was not needed, and deleting contacts and all the rest of it made no difference. It just does not make any sense...
      03-22-2012, 09:43 AM   #38
eskdale
I've seen some posts where it hasn't used the latest update.
What version does yours show now?
Should be 3.5.4
I really must get the duster out !! - It didn't look dusty until I took a photo - Really!!
      03-22-2012, 09:50 AM   #39
psyxologos
In the screen from which you took the screenshot (which I suspect is under menu --> Settings ---> Update), when I click update, it does not come with any of the options to update anything. It just asks me if I want to update via USB or teleservices (or something like that). But there is no list of updates available, which makes me think that Indeed I have the latest software. Please can you have a look at your firmware version and see if it is the same with mine that I posted yesterday? Thanks again. It really is mind boggling. I can see names and numbers in the recent calls section but not in the address book section...
      03-22-2012, 09:56 AM   #40
eskdale
If you select Teleservices it will go and check the versions - After a while of Data transfer it will tell you whether there is no update necessary or if an update is available
      03-22-2012, 09:58 AM   #41
psyxologos
I have just checked again in the BMW website, and upon entering my VIN I get a message that there are no software updates available for my car. So it looks like I have the latest software but the car and the phone have some sort of dissagreement...
      03-22-2012, 10:00 AM   #42
psyxologos
Yes. this is what happened. It just did not give the message. It reverted to 'service ready' and 'start service'. And as I wrote above, the BMW website confirms I do not need a software update. I really do not know what to think or say. I might dissable the 'office' function on the car and see if this makes any difference. But then again, how come my wife's phone work fine and mine does not? Very bizzare...
      03-22-2012, 10:43 AM   #43
eskdale
Something wrong somewhere here
The bmw bluetooth update site should give you the update even if it is up to date
If I put my vin in it gives me the option to download the update, even though my car is up to date.
Just to confirm how old is your car? It does have a combox fitted (post sept 2010 build)?
      03-22-2012, 07:05 PM   #44
psyxologos
My car has the com box and is post September 2010. I am resetting my phone now, erasing everything and I will load everything afresh. Fingers crossed.
