12-06-2015, 09:10 PM | #1 |
Rep 14,522
10" screen swap
So I'm really tired of looking at my little 7" screen if that's what size mine is but I wanted to know if the screen itself can be a straight swap to this 10" screen which also came off a 535 or is there more components needed? Appreciate any info you guys may have!
Mine looks like this
12-06-2015, 09:35 PM | #2 |
Rep 1,407
That's a micro screen bro! I believe the dimensions are the same. Check the connections in the back so see if they are the same. Might need some coding of the pic is going to be emitted to a wider viewing area. Hit up bmw retrofit... think the banner is patrys out similar.
12-07-2015, 08:53 AM | #3 | |
Rep 14,522
12-07-2015, 03:28 PM | #4 |
Rep 243
12-07-2015, 07:28 PM | #5 | |
Rep 14,522
12-07-2015, 07:39 PM | #6 | |
Rep 243
If you are going to buy the radio and screen, you should just suck it up and get the controller too and ditch the CIC all together. http://www.ebay.com/itm/BMW-5-series...pWZgO1&vxp=mtr |
12-07-2015, 08:53 PM | #7 | |
Rep 14,522
12-08-2015, 06:56 AM | #8 |
Rep 1,040
For navigation more wiring to the outside antenna is needed, check this tread http://f10.5post.com/forums/showthread.php?t=809788
a conversion with detailed step by step pictures and all. I believe you will also need codding on top. Last edited by martin mustang; 12-08-2015 at 07:03 AM.. |
