2010 2011 BMW 5 Series Forum F10 Heat Exchanger Bolts Torque Specs |
03-03-2024, 06:41 PM | #1 |
Rep 127
I replaced head exchanger gasket 7 months ago and now noticed trace of oil leaks. At the time I reused existing bolts (M8X20) because I had ordered wrong ones (M8X25, other heat exchanger type) and needed to get the job done at that time.
For those with ISTA and Service Repair Manual I have two question before I proceed to fix oil leak. 1). What is torque specs for item #10 (prevoiusly used torque chart shown). 2). Is manual telling us to reuse the bolts or new ones are must per manual. Thanks in advance. Regards Last edited by Conserve; 03-03-2024 at 07:12 PM.. |
03-04-2024, 09:35 AM | #2 |
Rep 2,591
16nm, can reuse bolts.
2015 BMW 535xi
ChiltiCoatl891775.00 Conserve186.00 |
03-04-2024, 07:18 PM | #3 |
Rep 127
Unspec Thank You for your respond. I am going to monitor it now and if it continues to leak I will replace gasket with OEM ones. Because I double check torque specs and it is right-on and with that it leaves me to think is the gasket.
ChiltiCoatl891775.00 |
03-15-2024, 10:50 PM | #4 |
Rep 436
Drives: 2016 F10 BMW 535i M Sport
I just got this gasket and the OFHG and I have watched and read it must be done very carefully, thankfully on my car it has been replaced already at around 40k however I am waiting for the day to see the leak appear from around that area. Hope you got it all taken care of!
