2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Springs or Coilovers?
      02-10-2015, 11:37 AM   #1
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
With Spring coming soon my car will finally be lowered. Problem is over the winter I've seen alot of pictures posted here and I'm wondering...for those who went with "Springs" are you happy with the drop? About how many fingers between the wheel and fender? And than I'll see someone posting pictures with a coilover drop where the wheel sits just a Tad in the wheel well and people will post "too low for my liking!" If you guys can give me your opinion I would appreciate it! I know it's my car and I should do whatever I want but I always like to hear opinions. Thanks everyone! Oh...if I do coilovers I'm leaning towards KW V1 or V2.
      02-10-2015, 01:28 PM   #2
Roswell
Drives: 2012 535xi
If u want a minimal drop & u are not tracking ur car, springs is more than enough.
Otherwise go with Coilovers. Much stiffer than oem shocks / springs.
I ordered the ACS springs, much more expensive than the H&R springs but I heard they are more comfy & I don't want a big drop so it should work just fine for my needs.
      02-10-2015, 01:35 PM   #3
VMRWheels
VMRWheels's Avatar
2040
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
+ 1
Adjust-ability is a key difference as well. Depending on which coilover system you get: dampening, ride height, camber can all be dialed-in to exactly what you like. Being able to adjust these things is not just for aesthetics, but may also open options for more "aggressive" wheel specs and benefit handling.
      02-11-2015, 09:08 AM   #4
lsturbointeg
So there's about a $700-800 price difference between the KW1 and Megan's. I did a search and seems like people have no negative but positive feedback on both coilovers. If it were you would you end up spending the extra $700-800 for the KW's? I'm on the fence here. The difference can go towards the install and other aftermarket goodies.
      02-11-2015, 02:54 PM   #5
gnhm3
gnhm3's Avatar
219
Drives: F82 M4 / F87 M2
Go with the KW. The 2 are not even comparable. Just my opinion.
      02-11-2015, 08:37 PM   #6
lsturbointeg
Appreciate that!
      02-26-2015, 12:49 PM   #7
lsturbointeg
Just curious but which springs give the biggest drop? Reason I ask is some ppl have added springs and weren't to happy because it still didn't sit low enough for their liking
      02-26-2015, 06:28 PM   #8
Genovese45
Drives: 2020 M850 Gran Coupe
I just bought the h&r and they are said to lower your front 1.5 in the front and 1.3 in the rear. You can use a tape measure against your fenders to get an idea of where your car will sit after it settles. Good luck. I went with springs over coil overs because it was more cost effective and I wanna save towards an exhaust system.
      02-26-2015, 07:44 PM   #9
badblack550xi
badblack550xi's Avatar
coil overs.... springs suck my car still feels like crap
2011 550i RWD 60-130 7.35
      02-26-2015, 08:23 PM   #10
lsturbointeg
Yeah...same here! Contemplating because if I go springs it would leave me more money for other mods...but I'd hate to drop it with springs and end up wishing I should've gone with coilovers. I still have another month to decide but I'm about 75% coilovers!
      02-27-2015, 09:49 PM   #11
calbear550
Drives: 2020 M5, 2020 X4MC (retired)
i like my coilovers a lot. they are stiffer and can be set up to be less so if desired. it does allow you to be more aggressive with the wheel set up (as you saw already) and not worry about bouncing around and rubbing over every bump. and if you overshoot on offset or tire choice, the ability to raise it or lower it, is very convenient. after my install, the car felt like a whole new one. it handles so much more better and i like that it's a tighter set up especially with some spirited driving. if you can swing it, go for it!
      02-27-2015, 10:17 PM   #12
lsturbointeg
Another reason why I want to go with coilovers! Thanks for your insight....BTW...what coilovers r u running?
      02-27-2015, 11:22 PM   #13
calbear550
kw v2's.
      02-28-2015, 12:08 PM   #14
lsturbointeg
Anyone have experiences with the CKS? They run about the same price as the KWV1's?
      03-11-2015, 11:52 AM   #15
dmoney23
Drives: 2011 bmw 528i m-sport
if you have adjustable suspension already I forgot what it is called on the f10, what coils or springs are best?
      03-11-2015, 12:43 PM   #16
lsturbointeg
kw v2's.
These! For $200 more I can go with these!
      03-11-2015, 02:23 PM   #17
AutoTalent
AutoTalent's Avatar
2309
Drives: e92 M3 6mt | e60 M5 6mt
KW!
