2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum condensation/moisture inside xenon headlamps
      02-11-2012, 06:36 AM   #1
cherrybeemer
Member
Drives: 2015 F32 M4
Hello, noticed alot of moisture inside the headlamps so took the car to bmw to have a look at it after which they said this is normal in xenons as they are vented and due to the current cold weather it s not clearing as quickly as it normally would. Is this true, does anyone else have this with xenon headlamps?
Thanks
      02-11-2012, 07:11 AM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
If yours are similar to mine as shown on pics, then it will go away after couple of months.
      02-11-2012, 07:16 AM   #3
bobblehead
bobblehead's Avatar
Drives: warp speed
If yours are similar to mine as shown on pics, then it will go away after couple of months. Note: this happened right from the first day I picked up the car.
      02-11-2012, 07:27 AM   #4
MalithS
Drives: BMW F10 LCI 530D Luxury
Thanks
Hi,
Yes this is quite normal. I had the same on mine and dealer said it was normal and nothing to worry about as the vents on the lamps will cause a little condensation to form. Mine does go away after driving the car a bit and lights after lights are used. Dealer did however say that they have logged this so that if it does cause a problem later they will be able to sort this out.
MalithS
      02-11-2012, 02:14 PM   #5
NYF32DRIVER
NYF32DRIVER's Avatar
Drives: 2016 428i X Drive
Yep...
Same thing here.
2016 428i X Drive. Mineral Gray Metallic. Born 2/2016, Munich Factory.
Member BMW CCA Since 2008
      02-11-2012, 02:24 PM   #6
martin mustang
Ireland
257
Drives: 640d,X5 45e, 911c4s, 635csi
same on my 5 series and my wife X3 both with Xenon lights.
      02-11-2014, 06:56 PM   #7
psyxologos
Drives: E46 330 ci SE, F11 530d SE
I just had mine changed by BMW under warranty (expires in two weeks) as there was a small condensation issue. Whilst the condensation came and went, and the technician said he did not see anything wrong with them, there was an ever so slight moss like substance making an appearance so they went ahead and changed them anyway. I cannot fault them, they were very helpful.
