2010 2011 BMW 5 Series Forum F10 JBL ms8 speaker config F10 hifi |
06-01-2015, 11:37 PM | #1 |
Rep 1,607
Drives: 2020 M8 Comp First Edition
So I installed ms8 with technic plug n play harness. Everything is working fine except rear speakers always cut in n out when logic 7 turned on.
Also when I did the set up ms8 will only let me choose front, center and side (which hifi don't have) speakers and rear ones have only none as the only option. I have tried side speakers as none thinking may be rear will give one way option but they always stay as none. I chose sub x 2 fr one way Center one way Side one way Rear has only none option. Any ideas. Thx
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
06-02-2015, 12:44 PM | #2 |
Rep 1,607
One thing I figured out today while set up keep ms8 volume at -40 and do every seat calibration then set to all instead of driver and make a nice surround system.
GT
06-02-2015, 03:18 PM | #3 |
Rep 9,097
Answer to first post;
Rears / side speakers are treated same on ms-8 and they are for ambiance (hence fading in and out). Now moving on to second post, when you set position to 'all' then it takes out time alignment. Not good for true audiophile. I had ms-8 in my previous car and now got bit one. Although bit one is good for spl setup but I miss MS-8 and its sql which is superior than bit one!
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
06-05-2015, 12:43 PM | #4 | |
Rep 12
Cool on the install. Did you have an amp and upgraded speakers before you added the MS-8? If so, have you seen a huge change in sound quality?
06-05-2015, 09:50 PM | #5 |
Rep 1,607
It's was just stock hifi system and all I did is changed stock amp to ms8. Huge improvement must upgrade. On par or better than my wife's b&o in her Audi.
GT
06-07-2015, 03:08 PM | #6 | |
Rep 1,607
GT
