2010 2011 BMW 5 Series Forum F10 285 WHP /// 535i Dynojet |
10-21-2016, 06:06 PM | #1 |
Rep 330
Hi Guys,
I have ordered ESS tuning and decided to see the result before and after. BMW M 535i 2013 RWD. Before: 285 whp/ 289 Torque with Armytrix Downpipe and Exhaust. Gas 91. After: I will post it next week after I install the ESS tuning. What do you think guys? Last edited by sqeezed; 10-21-2016 at 11:06 PM.. |
10-21-2016, 06:13 PM | #2 |
Rep 447
Drives: 2011 750i
Looking forward to the results
10-21-2016, 06:57 PM | #3 |
Rep 465
Im getting my car Dyno on tuesday, would be cool to compare now knowing what a semi-stock car puts out
2013 F10 535i M-Sport Alpine White Oyster/Black OEM M5 Exhaust with Resonator Delete |
10-21-2016, 09:35 PM | #4 |
Dream crusher
984
Rep 2,421
Is that with the exhaust and DP or solely stock?
Those number are accurate for base / stock
IG: @bmwdoubles |
10-21-2016, 11:05 PM | #6 | |
Rep 330
Expect these warnings (images attached)after you leaving and the car will be heavy but when you get home turn on and off the traction control and turn off your car leave it till the battery turned off totally then everything will be back the same. good luck |
10-21-2016, 11:17 PM | #7 | |
Rep 14,522
with DP i would think it would be a bit higher no?
10-21-2016, 11:18 PM | #8 | |
Rep 330
lol man I was expecting to see way more.. Do you know how they counted to HP? |
10-21-2016, 11:44 PM | #10 |
Rep 330
I found this link http://www.mk5cortinaestate.co.uk/calculator4.php
10-22-2016, 12:06 AM | #11 |
Dream crusher
984
Rep 2,421
You have to tune to your hardware, but your DP should've bumped your torque 20-30tq. I'm shocked too. The good news is it will all come together on the tune. The exhaust is just for fun, but the DP you should be able to squeeze an extra 15-20whp if the tune accommodates for it. Plus you need it to dispense heat at a faster rate for the extra boost you'll be running.
Plus armytrix is saying HP not WHP, but still 15% loss should still yield some power. Contact them with your Dyno. Does that come with some software of theirs?
IG: @bmwdoubles |
10-24-2016, 12:30 PM | #12 |
Rep 1,214
Proposed, estimated engine output gains do not automatically stack on top of existing at the peaks.
Power/torque gains are best represented when it states at what RPM the increase(s) are recorded. People have a really really bad habit of just adding numbers up in their heads because they don't have a working understanding of how engines generate torque. |
10-24-2016, 02:04 PM | #13 |
Joint Chiefs of Staff
24171
Rep 190,750
Sub'd for results
10-31-2016, 05:32 PM | #14 |
Rep 330
Sorry guys for delay. I have no experience with other tune how powerful they are but the car is so different I have 3 steps to maximum the power and I need to adapt the engine for each step. I will Dynojet later, maybe mid next month just to be safe and make sure the engine is working good with the tune. thanks all
10-31-2016, 07:26 PM | #15 |
Rep 447
Drives: 2011 750i
@ZennnZennn What step are you on now? How long are you allowing your car to adjust to each stage before you change settings?
