2010 2011 BMW 5 Series Forum F10 BP Ultimate diesel - worth it?/ waste of time |
08-27-2012, 02:55 AM | #1 |
Rep 5,093
Out of curiosity, I filled up with BP Ultimate diesel at at the weekend in my 530d. Quite a bit more expensive (around £1.51 per litre - those of you in the states will probably choke when you read that!)
Not noticed any difference. Website doesn't claim any benefitis as regareds performance or fuel economy but its advanatages relate to cleaning the engine. Anyone care to comment on this fuel? Waste of time? |
08-27-2012, 03:33 AM | #2 | |
Rep 15,858
I really use premium fuel to help keep the engine cleaner internally. Having seen user pictures of a BMW diesel run exclusively on Ultimate over many miles, the condition of the EGR valve was just black, no soot deposits or coking. Typically on regular fuel the valve would be half full of coke. Imagine injector tip condition, inlet porting, condition around valves. I'm of the opinion, keep combustion at optimum rates if possible. I suppose a lot will depend on type of trips you make, like steady speed driving with hot running, vs. short cold urban trips. Whether you intend to keep the car, run it out of warranty and/or value slightly cleaner oil through service/oil change periods. If I wasn't using Ultimate I'd be shortening the oil service intervals and even more concerned about DPF regenerations during local use. HighlandPete |
08-27-2012, 04:28 AM | #3 |
Rep 118
I notice that "Honest John" one of the Telegraph's motoring journalists recommends using BP Ultimate diesel. Don't know how much to read into that, but it's another recommendation at least. I use it when I come across it, but it's not exactly common on the Isle of Wight!
08-27-2012, 12:25 PM | #4 |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
I noticed a slightly more eager throttle response when I tried a few tanks of premium diesel but not a difference really noticeable to justify the price.
In my 330d that is, not my 328i!
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
08-27-2012, 05:25 PM | #6 |
Rep 2,064
Rather a waste of money. I've never noticed any difference.
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d |
08-27-2012, 06:39 PM | #8 |
Rep 203
I have been using BP ultimate fuels in all my BMW cars (E46 330Ci Se and F11 530D SE) and I definitely have noticed a smooth engine operation, better response and mileage. I have in a couple of occasions filled the cars with regular fuel and I am 100% certain the car was more sluggish. No placebo effect there.
08-28-2012, 04:32 AM | #9 |
Rep 15,858
There are tests out there which show the 'snake oil' has something in it.
Pehaps "Hissing Sid" only wakes up in some engines. Here's one test from TV's FifthGear motoring show. A test report from Car and Driving. http://www.caranddriving.com/feature...20ultimate.pdf HighlandPete |
08-28-2012, 06:13 AM | #10 |
Rep 5,093
having second thoughts about this. with the premuim fuel being about 10 pence per litre more , that only works out at about 70 pence per tank. AS a rule, I only fill up my tank once a month or tehreabouts that doesn't equate to much over a year so given from teh info you have posted in thei thread previosuly, its probably worth doing just to keep your engine in as good a condition as possible even if there is not noticable difference in performance or economy (even if there thechincally is a minute difference there)
08-28-2012, 06:27 AM | #11 |
Rep 1,663
Do you have a 7 litre tank?
2012 BMW F10 520d M-Sport
2010 BMW E70 X5 xdrive40d |
08-28-2012, 06:32 AM | #12 |
Rep 15,858
There is one factor about fuel use which is often ignored, that is the long term use and engine condition.
We often hear the "I've tried a tank of X, Y or Z fuel and there doesn't appear to be any difference". Possibly not, but what if the engine is not running clean anyway at the time of that trial? Say it is already losing best performance due to deposits building up. Do we really expect to see a marked change? Engine peformance often tails off and fuel consumption increases over time, so inefficiency builds up over time and use. That is what we really want to prevent. The better test is using fuel that keeps and engine clean and performs well all the time, then add a tank of normal fuel and feel the difference. An engine can often feel 'flat' doing it that way. Then go back to the premium fuel and you feel the improvement within a couple of miles, usually on the first blast of overtaking. Personally I don't see the wisdom in a tank of premium fuel "every now and again" hopefully to "suddenly" clean up a coking engine. The fact that the motor trade uses products like Forte to 'clean' a diesel engine inside and get back some performance and smooth running, indicates we lose performance over time. Some of us are just trying to help prevent that power drop off and the issues that can follow. EGR problems, etc. HighlandPete |
08-28-2012, 09:11 AM | #13 | |
Rep 203
08-28-2012, 01:35 PM | #14 |
Rep 507
Right - I'll give it a go while my car is still new.
August 2012 F10 520d SE sport automatic, Jet Black, Oyster\Black Leather, light ash wood trim, Professional media/ navigation, mobile apps, Internet, DAB radio.
08-29-2012, 02:03 AM | #15 |
Rep 261
The "it feels faster" thing is just your brain playing tricks on you. It's called a placebo effect and your brain does it to you to not make you feel like a fool paying for snake oil.
08-29-2012, 02:23 AM | #16 | |
Rep 507
Nobody here is saying that their car showed improvements even when they used ordinary diesel labelled as Ultimate diesel. That would at least be analogous to a placebo effect. Now get back under your bridge troll boy.
08-29-2012, 05:32 AM | #17 | |
Rep 203
08-29-2012, 11:48 AM | #20 | |
Rep 261
But you can bicker and banter all you want about the definition of the placebo effect. The point still stands. |
08-29-2012, 01:56 PM | #21 | |
Rep 15,858
If we are, the evidence is engine HP does increase under dyno testing, so some will "feel" a difference. MPG tests by Peter De Nayer (fuel economy guru) testing for WhatCar, did find an improvement in economy, with BP Ultimate compared to regular diesel, so some will "report" better mpg. If that is a placebo effect, then I have the wrong understanding of what test conditions and data are all about, and how it can crossover to user experience. HighlandPete |
08-29-2012, 02:55 PM | #22 | ||
Commander
14
Rep 210
I feed mine with Shell V Power and ENI Bluediesel only! Better performance and cleaner emissions.
Stay Ahead!
E46(00-03) - E46 Touring (03-06) - E90(06-10) |
