2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications ticking/clicking noise on turning
      06-08-2017, 03:31 PM   #1
cipher5
cipher5's Avatar
Drives: 2020 Donington Grey X3M Comp
When I turn I hear a ticking/clicking noise on turn... I have a 535i x-drive... Anyone else experience this? Was it the CV joint? I do have a 2011, not sure if it fits under the recall for rear CV joint, or if it's something else. Hoping its not an expensive repair.
      06-09-2017, 11:22 PM   #2
Sunnyc123abc
Drives: 550xi
I have the same noise on my 2012 550i. I thought it was the steering rack because when I move the steering wheel side to side with the car off I can hear it, but it seems to also happen when I am turning and the suspension flexes. The noise is very annoying, hopefully someone has a fix.
      06-26-2017, 02:56 PM   #3
cipher5
cipher5's Avatar
I have an appt with the dealer on Monday... I hope it's a recall or just normal behavior... instead of an expensive repair.
      06-26-2017, 10:25 PM   #4
Sunnyc123abc
Drives: 550xi
Keep us posted. I read with others it was the steering rack.
      06-27-2017, 12:30 AM   #5
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
I had this same issue. Can't remember what they did to fix it but I know it was expensive. Thankfully I had warranty.
      07-03-2017, 02:14 PM   #6
cipher5
cipher5's Avatar
Ugh... both CV boots are torn and dry, left axle needs to be replaced, right one a new boot and grease can be put on. Dealer can fix for $2300 for the left axle and right boot or $3600 for both axles... ugh..
      05-18-2020, 01:44 AM   #7
ashmailusa
Drives: F10 535 Xi
Hello everyone,
Decided to continue in the existing thread.
535 Xi ~70k miles
Same issue:
Ticking/clicking noise on turn somewhere around right front wheel. Happens when I turn the steering wheel to the right more than 180 degrees. Around 2 clicks per wheel rotation cycle.
Also, I have very short random squeacking noises upon slow pass over speed bump/pulling from driveway with turned wheels.
Was trying to diagnose those issues in indie shop. They didn't really find anything: squeaks are from old bushings, suspension seems to be tight. The ticking noise not obvious, yet they believe the issue is in CV/axle.
I still have 1 month of extended drivetrain warranty. Really want to fix it till expiration. Just want to hear your opinions guys.
Thanks!
      05-18-2020, 10:12 AM   #8
AlexRF10
Drives: BMW 535IX
Originally Posted by ashmailusa View Post
Hello everyone,
535 Xi ~70k miles
Same issue:
Thanks!
Check your strut mounts. I had similar issue going over bumps. All my suspension looked solid still which is very impressive for the age. All the BMW dealer did was re-torque one of the mounts and the noise went away. Be specific to the dealer about checking the mounts so they don't up charge you. When I took the car in I told them to fix a warranty item and check the mount first. They "inspected" everything else first and the mount last and charged me a few hours of labor for diagnostics, so be carful.
      05-26-2020, 12:35 AM   #9
ashmailusa
Drives: F10 535 Xi
So annoying. I actually dropped the car for inspection and diagnosis. They keep saying they don't see any issues. Yet, I can reproduce this ticking every time if I turn steering wheel 270 degrees...
      05-28-2020, 08:40 PM   #10
ashmailusa
Drives: F10 535 Xi
Oh boy.. I had to stop by to replicate the noise at the dealership.
Odd enough today I received update from BMW that they need to replace transfer box!!!
It was replaced less than a year ago.. Isn't that weird?
      06-12-2020, 09:31 PM   #11
ashmailusa
Drives: F10 535 Xi
The dealer changes right axle. The noise is gone!
      06-13-2020, 05:51 PM   #12
wrdriggs
Drives: F10 M Sport
I have the same issue intermittently, seems to be dependent on temperature, as well as how hard the steering wheel is turned
I do know theres also a TSB about calibration updates for the transfer case that are supposed to "help" this issue.
SI B27 02 13 "Knocking Nosie Coming From Driveline During Low-speed Turning"
      02-03-2023, 09:32 AM   #13
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
If the strut tower bolts are loose, it will rattle. Those who plan on tightening these bolts, take care in torquing bolts. They easily strip.
