11-21-2017, 08:56 AM | #1 |
Rep 2
M5 wheel help??
Hi guys newbie here. I'm picking up a set of m5 wheels from a friend for cheap. I have a 2011 550i x drive. The m5 wheels are 20 inch rear 19 inch fronts has anyone ram staggered wheels on there xdrives? If so how did you match the tires front to rear so the all wheel drive isn't affected ?
Thanks in advance Sam |
11-22-2017, 12:23 AM | #2 |
Rep 14,521
the offsets for those M5 wheels are not the same offsets your 550i needs. also, from what i've read here running staggered is normally what you run on a xdrive but as long as the diameter is within tolerance you're fine. there's quite a numerous threads here regarding fitment for the xdrive. also 19" front and 20" rear?
