2010 2011 BMW 5 Series Forum F10 Caliper Fitment question |
02-27-2022, 08:52 PM | #1 |
Rep 38
Hi all, i came into possession of a X7 brembo caliper - blue with M logo (thanks to a buddy getting rid of extra parts at his shop) . I also found another one for the right side that i can buy but before i do, i want to make sure i can get it to fit on my 550.
I know it needs a 395/36 rotor based on the numbers on the back so i was curious if anyone can provide some insight if there is a rotor that will fit.. For the caliper to fit, i assume i will need some spacers to center it on the rotor like the G30 retrofit. Thanks in advance!
2012 BMW 550 xDrive | n63intake.com goodies + tune | M5 Comp Exhaust | xHP stage 3 | xDelete | 20" HRE FF04
02-28-2022, 09:05 AM | #2 |
Rep 1,356
E60 X5M rotor should fit. You will need washers (4-6mm) to center the caliper to the rotor. If you use 6mm, get longer bolts as well. Depending on your wheel, you might need spacers as well
02-28-2022, 11:34 AM | #3 | |
Rep 38
i think i read somewhere someone was using the front subframe bolts and just cut them down when using the washers. Curious if the caliper will mount right up or if i will need bracket. I have the OEM 239M wheels for winters and HRE FF04 20x9 ET 25 for the fronts. Do you think i will need a spacer? maybe for the winter set?
02-28-2022, 12:43 PM | #4 |
Rep 1,356
No bracket needed.
Longer bolt is 07119908596. It just have to be M12*1.5*48. You can get them for cheap from local hardware stores. If it's longer than 48, you can cut it down to the length you need. I am not sure on the wheel. Just dry test fit them before you actually undo the brake lines. That way, you can put everything back and still drive. |
02-28-2022, 05:08 PM | #5 |
Rep 2,591
Be aware that G series calipers sit significantly more outboard than F series calipers. You'll likely need spacers. On 343M wheels, I needed at least a 7.5mm spacer to clear them.
2015 BMW 535xi
03-01-2022, 04:41 PM | #6 | |
Rep 38
03-01-2022, 04:43 PM | #7 |
Rep 38
yeah I feel like I might need spacers for the winter set. Hopefully for my summer wheels though. *fingers crossed* I might poke more than I like with a spacer that size.
03-02-2022, 02:35 PM | #9 |
Rep 38
will do! looking to borrow a lift at my friends shop this weekend - still too cold for outdoors work in the north east lol
03-07-2022, 08:06 AM | #10 | |
Rep 38
Also see a bunch of e70 x5m guys using f85 rotors which are the same other than 2 set screws instead of 1 (e70 guys say 1 is fine) and they are cross drilled vs normal.
03-07-2022, 01:24 PM | #11 | |
Rep 951
03-08-2022, 08:43 AM | #12 | |
Rep 38
03-10-2022, 09:09 AM | #13 | |
Rep 38
I still have life left on this current setup so i have a cart ready to go - will update the thread when i tackle this swap.
03-10-2022, 11:39 AM | #14 |
Rep 951
https://www.ebay.com/itm/154494087780
two piece Brembo rotors for the x5m for just under $400. Zimmerman I believe are a single cast design |
Blue Angel999.00 |
03-10-2022, 12:45 PM | #15 |
Rep 1,038
03-10-2022, 01:53 PM | #16 |
Rep 38
