2010 2011 BMW 5 Series Forum F10 Driver side rear sagging 2cm/1", front passenger sagging 3cm/1.5" - Any ideas |
06-28-2019, 06:08 AM | #1 |
Rep 43
I noticed my front near side seemed slightly lower than the offside so decided to measure from symmetrical points of reference on either side. The left (near side) is 3cm or 1.5" lower than the right (offside). I checked the rear and found the opposite; left is 2cm/1" higher than right side.
Tyre pressures seem OK (35psi) Firstly, should I be worried? Secondly, what could cause this? Note that I have Adaptive Drive, with active dampers and roll bars. Does this suggest a problem with them? Thanks
2014 F11 535 Touring
06-28-2019, 07:16 AM | #2 | |
Rep 15,858
06-28-2019, 08:22 AM | #3 | |
Rep 43
I took a quick drive around the neighbourhood looking for a surface where I could get the 2 rear wheels at the same elevation (ie no slope left to right) but could not find one, even when parking perpendicular to the road. I did not fancy parking across the camber in the middle of the road. So I have not yet been able to prove this is the cause, but it does seem likely. Thanks again.
