02-07-2015, 12:17 PM | #23 | |
Rep 86
Anyhow he did agree to bring the matter up with his line manager and possibly a phone call to BMW UK. He said I will be contacted on Monday with the possibility, slim or otherwise, of replacement discs. Interestingly during our discussion he said if they agreed they would only replace the fronts or rears, not both. I got the impression that they have to do this a lot. I would regard it a result if I got a set of rear discs out of them, time will tell. |
02-07-2015, 01:23 PM | #24 |
Rep 32,881
If they change the discs they'll have to change the pads as well! So will be a result!
So i'd get them to do fronts as the rears won't wear out for years anyway! |
02-07-2015, 01:56 PM | #25 |
Rep 86
The fronts aren't too bad, I can live with them, if they decide not to help out I'll look into getting the discs skimmed on the car.
When the weather warms up I'll tackle the corrosion on the hubs and callipers. |
02-08-2015, 08:19 AM | #26 |
Rep 267
Pretty much what I anticipate too ...... pathetic really ... altho shows how they watch every penny going into build cost - reminds of that novel .... based on building the 'Edsel' ......
M140i LCI-2 is the 16th BMW since 1977 ....
320i *2, 323i, 520i *2, 540i, 535i, 840i, E36 M5, 328i, 530i, 320d, 535d, M135i, M140i * 2 |
02-09-2015, 03:08 AM | #28 |
Rep 267
I was looking for 17" or 18" steels last autumn as 'Winters' .... did find some listed in EBaY Germany .... but turned out to be out-of-stock .....
02-09-2015, 04:19 AM | #29 | |
Rep 15,858
BMW do paint some of the callipers, like the performance brake options, I've also noticed 6-series have the standard calipers painted black. But we look at a 6-series and ask why the price hike over a 5-series? Painting calipers is one of the costs which reflect in the retail pricing. Do we want to pay more for painted calipers? I wonder how many would tick say a £200 option, to have them in enamelled black? Since we moved away from asbestos based brake pads, we've moved to softer iron discs, one reason they rust so easily overnight when there is any moisture in the air. You should see my discs this morning, all shiny Saturday afternoon, now brown with rust in less than 40 hours sat on my drive. HighlandPete Last edited by HighlandPete; 02-09-2015 at 04:29 AM.. Reason: spelling |
02-09-2015, 04:22 AM | #30 | |
Rep 15,858
HighlandPete |
02-09-2015, 06:17 AM | #31 | |
Rep 267
I'm not talking about expensive painting of callipers, just a treatment to prwevent rust ... they do it on so many other areas of the car ! (including the notorious 3-series disc-hubs) Iron discs have always rusted - it soon scrubs up with use .... better than the attempts using Stainless, which are less effective in the wet ....
02-09-2015, 06:51 AM | #32 | |
Rep 15,858
But we do hear the 'penny pinching' comments regarding BMW brakes. You mention the 3-series disc hubs, am I reading you correctly, but that is a case in dispute with many users, as they rust so quickly and look awful? The problem with surface rusting, it doesn't always "scrub up", can so easily turn to corrosion particularly on the outer edges and requiring premature disc replacement. See it so often up here, many discs get replaced well before the first set of pads are even half worn down. My local VW dealer commented on the rate of corrosion and lots of warranty claims on discs, particularly since using softer iron material. My F11 disc at low mileage, the pitting you can see, soon helps generates surface rust overnight. From my 330d at low mileage, if the disc surfaces don't scrub up, you soon get the corrosion eating in from the outer edges. My F11 front brakes are doing the same, no amount of use corrects that problem. You soon end up with discs like this, as on my 330d. HighlandPete |
02-09-2015, 07:11 AM | #33 |
Rep 619
BMW told me, when I had the hubs painted on my E60 prior to the F10, it is something to do with what paint can be used in the factory in any decent quantities. If they painted all the hubs that would require different paint to the body, maybe more oil than water based? and that would upset their credentials.
Could be rubbish but makes sense, hence why dealers will paint them with BM approval outside of the factory, but not in.
2017 F10 535d MSport Auto - Mineral Grey - Oyster leather - 19" 351M's - Pro Media - Enhanced bluetooth - MSport rear spoiler - Sun protection glass - Harman Kardon Hifi - Multi Function Display - Ambient Lighting - Folding mirrors - Sunroof - LED adaptive headlights
02-09-2015, 11:48 AM | #34 |
Rep 267
@ HighLand Pete - those discs are pretty shocking !
Strange that your F11 caliper aint too bad - at least the 'inspection plate' isnt rusty like mine!
02-09-2015, 02:31 PM | #35 | |
Rep 15,858
HighlandPete |
02-09-2015, 04:57 PM | #36 |
Rep 619
How bizarre, mine look nothing like them at all at twice the mileage! Must be where we live or something.
02-10-2015, 04:24 AM | #37 | |
Rep 15,858
I find up here that cars which don't get used every day get much more disc corrosion. Plus being in a rural area, many cars don't have enough heavy braking to clean discs off during use, so corrosion gets a hold. HighlandPete |
02-10-2015, 10:47 AM | #38 |
Rep 86
Still waiting for my dealer to get back to me with a decision about my discs (if they bother), if I have no luck I am considering having the discs skimmed. There is a garage not too far away that does them on the car @ £29 + VAT per disc, just the expense of new pads which is a bit off putting.
02-17-2015, 10:37 AM | #39 |
Rep 86
After a couple of non returned calls I received a message from the service manager, who happily offered to paint my rusty discs. He clearly didn't understand the situation and after I explained the problem to my surprise he immediately offered to replace discs/pads......result!
02-17-2015, 10:54 AM | #40 | |
Rep 1,207
02-17-2015, 01:44 PM | #41 |
Rep 86
gspannu, I think it was the 400+ mile return trip to see you on the salty gritty motorways and then parking the car up for a week that gave the rust an opportunity to take hold.
In future after a drive on salty roads I will wash down the brakes and drive around the block to dry them out. I will also be coating the hubs as you have done. I really hate the look of rusting corroded metal on an otherwise immaculate vehicle. Very happy with the eventual response of the dealer though, they could have quite easily sent me away empty handed, perhaps customer satisfaction does still count for something. |
