2010 2011 BMW 5 Series Forum F10 N55 Behind the Grill Intake DIY |
05-17-2021, 03:07 PM | #45 |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
Sweet! I reached out to David Shroup to get proper instructions for logging - I did notice my WGDC hitting 100 pretty quick after I started paying attention to it.
We'll see what he says. Maybe I need to put a shield in front of it but I really do NOT want to undo this intake LOL |
05-18-2021, 12:19 PM | #46 | |
Rep 529
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
05-18-2021, 03:24 PM | #47 |
Rep 505
Drives: 2013 BMW F10 N55 535i XDrive
Could we get a pic of the whole engine bay.. see what it looks like with out all that plastic??
05-18-2021, 05:25 PM | #48 | ||
Rep 1,445
05-18-2021, 05:27 PM | #49 |
Rep 1,445
There are links in this thread to my insta with the pics u r looking for. Or @browbmw on Instagram
musclesmarinara75206.00 |
05-18-2021, 08:34 PM | #50 |
Rep 505
05-19-2021, 09:01 AM | #51 |
Rep 2,595
Did you go back to stock intake?
2015 BMW 535xi
05-19-2021, 04:17 PM | #52 |
Rep 1,445
FYI IAT are down... I ran at about 15-20 degrees over ambient temperatures when at full operating temp prior to the intake. Now I am 10-15. 10 when moving, 15 when stopped and it recovers down to around 10 again. So good news there.
I will have to set it up to full heat soak then see how well it recovers. |
05-19-2021, 04:51 PM | #53 | |
Rep 1,230
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
05-20-2021, 07:59 AM | #54 |
Rep 1,445
That looks sick. If having it behind the grill causes problems I'll put the filter where MST put it, and then use this to feed the air into that area... I like that. Thanks.
satta535i22.00 |
05-20-2021, 09:07 AM | #55 |
Rep 2,595
I thought velocity stacks were used for the intake itself e.g. right behind the filter? It seems like a bit of a waste to use it to just funnel air
2015 BMW 535xi
05-20-2021, 12:58 PM | #56 |
Rep 1,445
Maybe, but either way, if it pushes more air it'd be a cool way to funnel air into the air box.
05-20-2021, 01:58 PM | #57 |
Rep 2,595
BMW already uses what is effective a velocity stack from the factory with part number 13717577469. You won't see any more air than normal.
2015 BMW 535xi
05-20-2021, 02:15 PM | #58 | |
Rep 1,445
And, the volume of air that can go through that pass through was also increased when I used a heat gun to get a 3" diameter tube through it... so there is that too. |
05-20-2021, 02:59 PM | #59 | |
Rep 2,595
2015 BMW 535xi
05-23-2021, 11:50 AM | #60 |
Rep 1,230
i like the method of using a velocity stack sucking in air through one behind the grill than a cone filter scavenging air from everywhere.. outside..engine bay especially if that intake cone sits right near the radiator and condenser on hot summer days. Purpose of the velocity stack is to have one steady stream of air flowing into the intake pipe. If you disassemble the skunk 2 filter it comes in two parts and is designed right.
N55 GENERAL
05-25-2021, 01:47 AM | #61 |
Rep 529
Yes I have the stock back on with a K&N filter
05-31-2021, 11:41 AM | #62 |
Rep 668
any update on the intake? impressions now that you're driving it around in Mexico??
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
07-08-2021, 02:25 PM | #64 |
Rep 104
Check out the new Turner Motorsports intake: https://www.turnermotorsport.com/p-1...8aAkJhEALw_wcB
Bench Flow tested, 22% increase over stock. Any thoughts? |
07-08-2021, 03:21 PM | #65 | |
Rep 1,445
It's just REALLY EXPENSIVE. Too bad they didn't do a plastic version, woulda got the same result but they wouldn't make as much $$$. I bet my intake flows just as much as theirs do if not more because of I addressed the Inlet. I really need to edit my intake video.... sorry guys, just been really busy and no one is asking anymore lol. |
07-08-2021, 04:08 PM | #66 |
Rep 104
Your intake will definitely flow more air. Did you had to do any cutting of the car to get the intake to the front of the radiator? Are you having any problems like BMWdoubles with too much air?
Yeah I would buy the plastic version for a $300-$400 discount off the CF version. |
