01-30-2018, 07:40 AM | #1 |
DROPPIN' LOADS
31
Rep 245
Drives: 2019 M5 Competition
Battery Question...
So I store my car throughout the winter under a cover in a garage and I do try to start it up at least once every 2 weeks and let it idle for 5-10 minutes but the last 2 times I'm getting a battery charge warning light that tells me to drive for an extended time to charge it.
Problem is I'm not going to take it out on the pothole and salt ridden roads right now just to charge it and risk paint chips or a broken rim. I know why the battery is losing power, but shouldn't it hold a charge a little better or do i just need to let it idle for longer so the alternator does its job? Dealer said not to unhook the battery as it's powering systems even when the car is not running. Thoughts? 2015 550i with 21k miles so the battery is still in great shape.
01-30-2018, 10:18 AM | #2 | |
Rep 155
Get yourself a battery tender such as the CTEK MXS 5.0 and leave that attached to the charge points under the bonnet while you are not driving the car for an extended period. It will fully charge the battery then continue topping up the charge and is quite safe. If not the model I mention, make sure it has a setting specifically for AGM batteries which is the type fitted to our cars. |
01-30-2018, 01:38 PM | #3 |
Rep 937
01-30-2018, 01:49 PM | #4 | |
DROPPIN' LOADS
31
Rep 245
01-30-2018, 09:08 PM | #5 |
Rep 14,522
car has to be driven in order for the battery to charge. letting it idle won't charge the battery at all. my car was like yours...during the winters it would sit in storage but i would make it a point to start it up and drive it around for 30 min. i hear ya about the road salt but a quick wash will help prevent any corosion
01-31-2018, 10:32 AM | #6 |
Rep 1,254
I store my car over winter as well
Letting your car idle wont do nothing but get engine warmed up and fluid moving trough engine. Driving your car around bloc wont do nothing for your battery again it will help getting engine up to temperature and you wont have flats spots on your tires. Now what can you do to benefit your battery is buy trickle charger and hook it up at least twice a month or more it will keep your battery healthy.
01-31-2018, 10:35 AM | #7 |
Rep 1,254
NO need for fancy BMW logo charger just go to Wallmart buy one for $15 will work just fine trust me
That's what I did I been using my for years no issues
01-31-2018, 04:02 PM | #8 |
DROPPIN' LOADS
31
Rep 245
Appreciate it fellas. Bought one and will hook it up when it arrives tomorrow.
EL Jeffe 5611.50 |
