2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 Sport Oil Cooler Valve
      01-02-2019, 01:14 PM   #23
warpeacelove
Drives: 550i
Originally Posted by 335socal View Post
DIY on this.
Seller website has instruction: https://n63intake.com/product/n63-n6...-cooler-valve/
      07-26-2020, 05:19 PM   #24
Bkristes
Drives: F10 m5
Where does it located on f10 m5
      07-26-2020, 05:20 PM   #25
badblack550xi
badblack550xi's Avatar
Inside oil pan
2011 550i RWD 60-130 7.35
      07-26-2020, 06:29 PM   #26
Bkristes
Drives: F10 m5
Do i need gasket after i remove oil pan ?
      07-26-2020, 06:31 PM   #27
badblack550xi
Yes
      11-08-2020, 07:57 AM   #28
Stairway2Kevin
Drives: 2013 BMW 550i M sport
Originally Posted by badblack550xi View Post
Yes
does the oil pan need to be removed to change it out? I was under the impression it didn't by looking at your website??
      11-09-2020, 11:08 AM   #29
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
The N63 and S63 don't have the same oil pan design
2015 BMW 535xi
ISTA VM Setup/Tutorial
      11-10-2020, 07:29 AM   #30
Stairway2Kevin
ahhh I didn't catch that he was talking about the other motor there, awesome thanks for the reply!
      11-24-2020, 11:56 AM   #31
AnotherM
Cole
Drives: 2016 m5 CP
So I had a shop try and install this valve and it doesn't appear to fit. The OEM valve sits all the way down. Is the part defective or is this how it is supposed to be installed?
      11-24-2020, 12:02 PM   #32
Unspec
Unspec's Avatar
1301
As per the website:
Spring will sit higher than stock that is normal, insert it back and tighten the plug.
Though based on your pics it looks a bit TOO much higher.
2015 BMW 535xi
      11-24-2020, 12:05 PM   #33
AnotherM
Cole
Drives: 2016 m5 CP
I read that, but when we tried to put it back in, it really seemed like it wasn't going to go back in correctly. I thought it would be best not to chance it and ask first.
      11-24-2020, 12:07 PM   #34
AnotherM
Cole
Drives: 2016 m5 CP
Just a thought, if this valve is basically just opening the valve 100% of the time, why not just remove it? I saw several videos of the n55 oil cooler valve being switch with its spring and essentially doing the same thing, but for free.
      11-24-2020, 01:54 PM   #35
AnotherM
Cole
Drives: 2016 m5 CP
So they confirmed from my pictures that it is correct. It should be installed like that which is as you can see at least an inch higher.
Kind of makes me think more that this valve could probably just be removed or easily modified to have the same results without the $200 price tag
      11-24-2020, 04:30 PM   #36
BBHMM
Drives: 550i
Did you install it?? How is that??? What is oil temperature you have with it?
      11-25-2020, 03:17 AM   #37
AnotherM
Cole
Drives: 2016 m5 CP
I did not install it. We were not able to get a response from them in time so it will have to wait until next oil change.
The customer service for them is terrible. Nothing but attitude and rude responses. I would never buy from them again and suggest everyone refrain from using any of their products. I think the community can use vendors who appreciate customers and strive to provide quality customer service.
      11-25-2020, 08:46 AM   #38
Unspec
Unspec's Avatar
1301
It's probably there to restrict flow. If it's completely gone, I imagine it might take too long to heat up.
2015 BMW 535xi
      11-25-2020, 06:11 PM   #39
AnotherM
Cole
Drives: 2016 m5 CP
This valve essentially makes the oil circulate through the oil cooler at all times. It is fabricated to compress the spring all the way and simulate a completely open stock valve. Would be the same as if it wasn't there at all unless I'm missing something.
      11-25-2020, 11:07 PM   #40
2manybimmers
2manybimmers's Avatar
Drives: Rebuilding the stable
Appears you did not follow the instructions on the website for install. I've known the seller for a few years now from the forums, he doesn't sell bad parts and if you're patient he will help you resolve the problem.
      11-26-2020, 07:55 AM   #41
AnotherM
Cole
Drives: 2016 m5 CP
Please read posts fully and comprehend what is being said prior to posting a reply. Your reply has no relevance what so ever. You had great experiences? That's great, but what does that have to do with mine?
Maybe I didnt clearly explain the situation in a way you would understand. A shop, not me. A shop pulled out the factory valve. When comparing it to the new one and looking at the instructions. We did not feel the new valve matched the description provided. (Compare image to description "spring will sit higher" it isn't the spring that is higher. The entire valve is higher. Ok, at this point if you're following me, we decided to wait until the seller replied to confirm we are good to proceed. The seller.and this is where the experience was negative for me(not the product to be clear since you seem to have misunderstood that part) replied with attitude and sounded like a jerk. Now, I was extremely frustrated that the description was so vague and that we wasted our time which means money when your at a shop so to receive attitude at this point was just not acceptable.
      11-26-2020, 11:05 AM   #42
badblack550xi
mind you i have a direct cell phone number you can call instead of emailing me.
this was your 1st email i have ever heard from you
Code:
So I just paid a shop to install this valve and it doesn't fit. I have a 2012 bmw 550i which this is intended for. See attached pictures with factory valve and your valve. Who is going to pay for the lost shop time? Is the part defective?
this was my reply
Code:
That’s how it goes in ! It sits higher !
that makes me a jerk and no one should deal with me ? you gotta be kidding me, do me a favor pack my valve back ill send you return label.
      11-26-2020, 11:21 AM   #43
2manybimmers
You're completely invalidated. Man, you just love to bitch. Go find somewhere else to cry because no sympathy will be found here.
      11-26-2020, 01:35 PM   #44
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
Code:
this was my reply
Code:
I'll buy it from the buyer, I stand behind Sergey's services. I have had nothing but great experiences and I personally have nothing negative to say about him. He was responsive even when I had my wife text him. But for real, I'll buy it from you right now!!!!
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
