2010 2011 BMW 5 Series Forum F10 N63 Sport Oil Cooler Valve |
11-27-2020, 06:59 PM | #45 |
Rep 1
Lol this is funny.. I back Serg 100% he is a stand up guy and always ready to help or answer ??? Even if you don’t buy shit from him.. I’m in SoCal and I wasn’t comfortable buying anything from anyone this far away.. I need to walk into a shop and deal with someone.. I picked up valve, thermostat and stage 2 tune that’s after 2 months of him answering every question I had after 12am est his time.. No One knows these cars better then him and I’m minutes from some of the top BMW tuners.. if that is not customer services I don’t know what is..
550bye1389.50 |
11-27-2020, 07:44 PM | #46 | |
Cole
321
Rep 498
11-29-2020, 12:07 AM | #47 | ||
Rep 262
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
01-06-2021, 11:31 PM | #48 |
Cole
321
Rep 498
Car was due for an oil change with all of the miles from the holidays so I put in the valve and it works exactly as advertised.
Again, Sincerely apologize for before to the seller. |
01-07-2021, 01:02 PM | #49 | |
Rep 951
I kid I kid I kid...no he's an awesome guy!! Glad it worked out for you!! |
550bye1389.50 |
10-14-2021, 11:32 AM | #50 |
Rep 156
OP states will lower engine oil temps to around 200f, my understanding was that engine oil temps needed to be at least 212 to vaporize moisture and burn off deposits in the oil. So lowering below that threshold would negatively impact the engine?
05-10-2022, 10:25 PM | #52 |
Rep 23
Drives: 2012 550i
Is the thermostat needed as well to get the temperature below 200°F? If oil cooler valve does a good enough job of cooling the engine, then that is the route I'd rather go.
09-07-2022, 07:44 AM | #53 |
Rep 2,416
over the the years of having the cooler on my personal cars including my F90 M5 comp, i have not seen any issues. My F10 550i had the cooler installed at 50k miles, it is right now at 150k miles with the new owner.
2011 550i RWD 60-130 7.35
09-07-2022, 07:45 AM | #54 |
Rep 2,416
Thermostat lowers coolant temps not oil temps, but lower engine temps will slightly make the oil run cooler also.
