09-07-2019, 10:35 PM | #1 |
Rep 54
Do I need shocks?
I put H&R springs on my 14 msport and every time I hit bump I hear something rattle. Not sure what it is? Is that normal. Everything is tight.
09-08-2019, 09:54 AM | #2 | |
Rep 38
https://www.newtis.info/tisv2/a/en/f...rakes/1LepByFD This will make the car sound like your entire suspension is just about to come off. I check mine up on every tire rotation or brake change. |
10-20-2019, 01:44 PM | #4 |
Rep 54
Checked the plates and they are tight. Took it to firestone and they said I didn't pressurize the shocks by having someone stand on the car while tightening the top hat.
But I still have the rattle. Going to check the back because I don't think they did those but it sounds like it's coming from the front. |
11-07-2019, 07:53 PM | #5 |
Rep 54
Took the car to Brake Plus to look at it and they found a bumper support broken. Still have a clacking sound from the driver side front. Has anyone had this????
I'm out of 270.00 for a 20.00 part and still have the problem. |
11-07-2019, 08:34 PM | #6 |
Rep 14,521
it could be anything really. I would get back underneath and start physically checking everything. retorque everything, double check anything that would cause the clanking
11-08-2019, 12:00 PM | #7 |
Rep 14
Check the Nut on the shaft of the strut. The one that keeps it attached to the Top Hat, it is likely you did not tighten the nut enough.
Who did your install? What method did you use to secure the nut to the top hat? |
11-08-2019, 01:23 PM | #8 |
Rep 916
Are the sway bar links good also bushings?
Instgram @burninja
