09-10-2015, 05:07 AM | #1 |
Rep 8
Steering
I have recently taken delivery of a new 520d SE. Delighted with the car but I had a problem with the steering (heavy and jerky it drove like a car pre power assisted). It went back to the garage and they replaced the steering box. The jerky action has been cured, i.e. it is now smooth but I still feel the steering is still heavy as compared to a loan 5 series car I had previously, also I do not notice any difference in the steering between comfort and sport. Before I go back to the garage again I thought I would ask for your input on the following:
- Should there be a noticeable difference between Sport and Comfort? - Is the steering heavy compared to 'other' cars? - As the steering is electrical can BMW change the settings? Your help would be much appreciated thanks |
09-10-2015, 05:32 AM | #2 |
Rep 1,040
If you coming from an E60 5 series or X drive car the steering should feel very light as the F10 is electric while X cars and E 60 hydraulic. if compared to F10, makes sure the wheels are same, i.e. size and type before judging the feel, mind you even with this factor in place it should be similar feel not easy to pick on, one last part to check is the tyres pressure for your front wheels is as it should be.
09-10-2015, 05:51 AM | #3 |
Rep 5,085
Re steering "weight" , I can feel a difference between comfort and sport but its subtle and only noticed at higher speeds. At lower speeds, I find it difficult to detect. Can't compare to a E60 as I've never driven one but I find the steering light compared to the previous E39.
If you drive at say 60/70mph and switch between the modes you should be able to tell. Just wondering if as a result of having the steering box replaced, software has also ben updated which might explain differences? My car is a 2012 and I've not driven any newer models so not sure if BMW may have changed any parameters or not. You can also make the steering heavier (as per sport mode) if you switch off the DSC completely whilst still in comfort mode.(whether you want to drive around with that off is another matter though!) I would personally love to have the E39 steering feel on my F10. |
09-10-2015, 06:11 AM | #4 |
Rep 628
Interesting,the steering on mine sometimes feels a bit jerky, hard to notice - but it is there. If I take it in, they will just say that they cant feel it.
G30 530d M Sport xdrive, Adaptive Drive and with all of the important options. |
09-10-2015, 09:17 AM | #5 |
Rep 1,597
The steering weight only changes if you have servotronic steering, this was not standard on earlier cars. Might be worth checking if your car has this...
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
09-11-2015, 11:43 AM | #7 |
Rep 5,050
I have a 2015 F10 with electric power steering and it's horrible, and although there is an improvement in sport mode it is hardly noticeable. I find there feels to be a vagueness around the straight ahead position, small corrections do feel jerky, and long straight roads (ie motorways) always feel like there are side winds calling for lots of these slight jerky corrections, it certainly isn't pleasant to use.
09-11-2015, 12:00 PM | #8 |
Rep 5,085
yes I have mentioned in other untelated posts , my personal view is that the steering is one of the 2 features that lets down what is otherwise a very good car. Your opinion may vary depending upon what you have driven before, coming from a E39 which i thought had nigh on perfect steering , I'm let dowm although you do get used to it though.
09-11-2015, 02:40 PM | #9 | |
Rep 15,858
I find the steering weighting for Comfort and Normal is fine, Sport setting adds heft, but adds nothing to the feel and feedback. I prefer the Comfort/Normal setting as you feel more feedback from the road. As to steering precision my F11 is fine, as the tyres wore it did lose a bit of accuracy, but tracks straight. I've just fitted a new set of ContiSportContact 3, (direct replacement) and have been down south and back (1,000 miles) and precision is fine, no corrections are needed whatsoever, even on badly rutted sections of motorway. Steering is smooth, always has been, no jerkiness at all. Jerky steering doesn't sound right to me, has the dealer passed comment? Have you tried another car to compare? Is the steering wheel position accurate 'dead centre' when driving straight? Any slight deviation can change the straight ahead precision and feel. The rack requires an exact mid position (steering angle sensing) to accurately process all the sensor feedback. HighlandPete |
09-11-2015, 03:46 PM | #10 |
Rep 5,050
The steering wheels is spot on & the steering is fine if I'm on winding roads, it's straight roads I find the problem, which I've put down to the fact that the EPS isn't doing anything until it is required eg: driving straight the EPS is doing nothing but when moving the steering (as in a correction) there's a slight delay in assistance so an initial resistance is felt which eases almost immediately as the EPS kicks in - this translates into a feeling of slight jerkiness, whereas in fact it's just the way that the EPS (with BMW Eco settings) works.
09-12-2015, 03:02 AM | #11 | |
Rep 15,858
Do you feel it is a more definite on-centre control, a bit like some cars have strong self-centre bias? I understand you point on the EPS being off power until required, surely BMW haven't exaggerated the on-off feel due to that function. I've driven EPS with that feeling, (not BMW) it's horrible, pleased my car isn't inflicted with such a feeling. HighlandPete |
09-12-2015, 04:10 AM | #12 | |
Rep 1,597
On a general note I do find the steering lacks feel...
09-12-2015, 01:56 PM | #13 |
Rep 5,085
that certainly begs the question then of which F10s do have it then?
I certainly didn't tick any option for it on my 2012F10 (msport with SAT) I'm confused then. Do this weighting up of the steering in sport mode only come with oterh options then> Msport perhaps or Sports auto transmission? I will have to look at my VO to see if its listed as a standard option then. |
09-12-2015, 03:30 PM | #14 | |
Rep 15,858
Current spec' list still show it as standard. HighlandPete |
09-12-2015, 03:55 PM | #15 | |
Rep 15,858
I've driven an F10 with Adaptive Drive and the standard auto and that changed the steering weighting with Sport mode. My F11 has SAT and AD and that I feel is even more marked when toggling to Sport mode. The suspension and steering changes combine to give more heft and enhances steering agility. The car 'shrinks', more 3-series like in Sport mode. HighlandPete |
09-13-2015, 02:02 AM | #16 |
Rep 8
Since posting this question I have driven another 5 series (F10 - 2015) and concluded mine is the same. I can now get back to enjoying the car as I just needed to be convinced 'all was well'. Thanks for your inputs.
09-13-2015, 08:24 AM | #17 |
Rep 1,597
Mine is an M Sport with SAT, I was surprised it doesn't have it either tbh...
