2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 550i Resonator Delete w/factory mufflers
      02-12-2017, 01:19 AM   #23
335socal
Drives: Alpine white 335 coupe
Originally Posted by Blu550 View Post
quieter with the resonator removed?
yes it is. it made me feel like im deaf. i will drill a hole before the muffler and see what happens to the sound.
dont have x pipe yet.
      02-12-2017, 07:19 PM   #24
335socal
Here is the sound clips of my resonator delete with drilled holes before the mufflers and butterfly valves open. sounds good and no drone at all. Cost less than $200.
      02-12-2017, 07:24 PM   #25
The_M6
The_M6's Avatar
Drives: 2013 M6
video won't play...here or on YouTube
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs
      02-12-2017, 07:36 PM   #26
335socal
really? iv been playing it like 3x now. maybe reset your browser.
      02-12-2017, 08:00 PM   #27
The_M6
The_M6's Avatar
Drives: 2013 M6
it sounds like mine without the hole drilled in the exhaust pipe.
If you're happy with it, that's what matters. It was still too "stock" sounding for me, had to go aftermarket.
      02-14-2017, 08:41 AM   #28
335socal
i will be adding some xpipe this friday. hope it will sound way better.
The_M6248.00
      02-20-2017, 09:15 AM   #29
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
did you get them installed? post a vid if you can
      02-20-2017, 11:28 AM   #30
335socal
not yet. still in the shop for rear diff bushing and ac compressor. extended warranty needa to send inspector for the claims. lol! so glad have extwnded warranty. i will post clips with xpipe as soon as i get it installed.
      02-20-2017, 02:27 PM   #31
BMWisFRIEND
Drives: '21 BMW M550i
I just had mine done for $200. I notice I hear a lot more of the turbo's spooling up now? Any else notice this too? Otherwise noise wise it's almost like I get some more engine noise at higher RPM (which I like).
The_M6248.00
      02-26-2017, 02:03 PM   #32
335socal
cold start!
With xpipe and butterfly valves open:
With xpipe and butterfly valves close:
The_M6248.00
      02-27-2017, 10:32 PM   #33
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
add badblack's intakes and it will take the sound up a coupe notches on the turbo sounds. loved them even before the exhaust upgrade.
      02-27-2017, 10:40 PM   #34
The_M6
The_M6's Avatar
Drives: 2013 M6
I concur...love my intakes! They compliment the exhaust perfectly.
      02-27-2017, 11:24 PM   #35
BMWisFRIEND
Did you get the full cold air intake system or the $350 ones?
Is the noise that different?
How hard was the install?
I'm sure I could find answers to these questions easily, but wanted to ask someone live.
      02-28-2017, 08:03 AM   #36
The_M6
The_M6's Avatar
Drives: 2013 M6
I got the complete N63intakes.com intakes. The sound isn't noticeable at all inside the car. On startup, they really "suck" and you hear the turbos spool and blow off during high rpm shifts or engine revs.
I did the install myself, took a little over 2 hours mainly because I didn't know what I was doing. The instructions are clear but the engine bay is tight. Serge was available via FB chat and he walked me through the whole thing. I did the driver's side first, took well over an hour but the passenger's side was about 30 minutes once I'd figured it out.
      02-28-2017, 01:17 PM   #37
BMWisFRIEND
Tempting...very tempting. Thanks for the info I'm tryna decide if I want to go through with the mod myself... prob would stick with just the drop in filter for now though (and would remove the carbon filter). The red I'm seeing under your grill in your profile picture, is that from the cold air intake upgrade you did/do you think I'd see it if I went for the cheaper route?
