2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 M5 Mufflers VS F10 550i Dinan Mufflers
      03-14-2017, 04:24 PM   #1
addy27
Drives: F10 550i
Folks,
I did try to search and while I could find individual threads on 550i Dinan and M5 stock Mufflers, I could not find a comparison of the two.
I currently have the F10 M5 Mufflers on my 550i and the sounds is quite impressive. However, I am thinking about the Dinan Mufflers for the 550i as from what I have read, the stock M5 F10 mufflers cause a noticeable reduction of low end torque.. (again, I have read it but not experienced it due to not going back to stock and comparing).
So my query really is what would most of you prefer on your cars if you had the choice between these two?
      03-15-2017, 05:50 AM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
from the guys who went Dinan a lot of them reported it's very tame.
      03-15-2017, 12:05 PM   #3
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Stick with the M5 mufflers. Do you have them hooked up to your vacuum line so the valves work?
I'm no expert, but I would be hard pressed to think that mufflers designed for an M car would yield a loss of torque.
@Stück might be able to chime in more.
      03-15-2017, 02:21 PM   #4
MissionPerformance
MissionPerformance's Avatar
Drives: '17 F31 340xi US Spec
The only time stock M5 mufflers cause reduction in torque is when they are not hooked up correctly. As AMTF10 said, make sure you have the vacuum lines hooked up. These cars use shared vacuum source for the exhaust flaps and turbo wastegates. If you leave your mufflers unplugged, the waste-gates will be lucky top build even 5 psi of boost.
      03-15-2017, 02:57 PM   #5
addy27
Drives: F10 550i
Vacuum lines are hooked up and and he valves are functioning as designed. I love the sound as it's nice and deep. I'm almost disappointed that I can't hear the same tone inside the cabin that I can if standing behind the car.
So besides the Dinan mufflers being tamer than the M5 mufflers, would there be any other reason to consider them? Dinan claims that the Dinan muffler will ad 10hp if combined with their stage1 Software. Would the M5 mufflers not give the same? (I may have a set of dinan mufflers on a for sale thread here if there is really no benefit over the M5 stock setup)
      03-15-2017, 03:06 PM   #6
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
I have M5 mufflers on my 535i. Seeing how my original muffler didn't have a flap and I don't have vacuum lines, am I doing myself a disservice by keeping the valves closed on my mufflers? I would open them but the drone is annoying, but at the same time I don't want to restrict power.
      03-15-2017, 03:23 PM   #7
MissionPerformance
You should be fine. M5 mufflers will flow enough air with the flaps closed for a stock or mild N55.
