2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications What is this tee'd from the charge pipe?
      02-25-2017, 07:05 PM   #1
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
What is this actuator or regulator of sorts that is tee'd off the charge pipe? Is. To regulate the pressure from the valve cover?
IG: @bmwdoubles
      02-25-2017, 07:41 PM   #2
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
Purge valve, vents fuel vapor in the fuel tank into the engine during decel to be burned off. There is a check valve on the valve cover side that allows some crankcase scavenging as well.
      02-25-2017, 09:13 PM   #3
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
That explains where that blue line goes off to under the wheel well. Thanks Stück
IG: @bmwdoubles
