2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N55 BMS Intake Heat Shield
      02-26-2017, 08:11 AM   #1
808_F10
Drives: F10 535i M Sport
Wanted to share the intake cover/heat shield I made for the BMS N55 intake. Inspiration came from user TVD75. I started with the information he supplied and adapted from there. Material is 14 Ga stainless steel with a lexan cover. I added some tabs on the outside to tap back into the original screw locations. Only problem is that it is tight against the hood sound dampening, you can see the indentations on the liner.
      02-26-2017, 04:28 PM   #2
paul223
paul223's Avatar
Drives: F10
Nice! But you are back to original setup.
      02-26-2017, 09:08 PM   #3
DigitalNav
Drives: 2013 535i M Sport
Doesnt this defeat the purpose
2013 F10 535i M-Sport
Alpine White
Oyster/Black
OEM M5 Exhaust with Resonator Delete
      02-26-2017, 09:54 PM   #4
AWF87M2
AWF87M2's Avatar
827
The only benefit I see with this is showcasing your engine bay during car meets.
      02-27-2017, 07:50 AM   #5
808_F10
The OEM setup includes an intake box that is sealed and pipes cold air in via a pipe that draws in air from the front of the car, which you can see forward of the intake. The BMS intake does not allow you to re-install the OEM intake cover because of the increased size of the filter. A typical BMS intake install will not have any type of heat shield (BMS does not make any type of cover), sucking in hot air from the engine bay. The purpose of this box is to create a barrier against the hot air in the engine bay and the intake, forcing the intake to suck air back through the OEM pipe. Of course this box does not create a perfect seal so some hot air will still seep in. The secondary purpose of the box is visual, hence the use of lexan rather an opaque material. Hope that clarifies what I was trying to achieve.
      02-27-2017, 05:16 PM   #6
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
Looks cool but the flow restriction is the smaller original airbox opening, which is why the intake is designed without a lid in the first place.
Mike
      02-27-2017, 05:25 PM   #7
07e92
Drives: 07 335i
good effort, but wonder why would there be a cabinet/organized box in the engine bay
      02-28-2017, 01:25 AM   #8
MMAFAN
Drives: 535i
I get what you were trying to accomplish and just wonder what the HP gain by shielding any heat from the engine bay. As far as the finish it looks great and all that matters if you are happy with the finish product. Thanks for sharing!
2012 535i M Sport - BMS Intake, Catless Downpipe, LPFP, Custom Titanium Exhaust
      02-28-2017, 07:58 AM   #9
808_F10
I don't expect any HP gains, not really getting any from the filter by itself anyway. The purpose is to try to keep cool air going to the car and to make the intake setup look good.
      02-28-2017, 10:08 AM   #10
Nexo
Nexo's Avatar
Drives: E70 x5 2011
2011 X5 e70  [0.00]
very nice, I like the mod... even helps to keep the heat out well done.
      02-28-2017, 11:59 AM   #11
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Can you provide guidance on this? If you made one of these for sale I would totally purchase it.
      03-01-2017, 02:39 PM   #12
808_F10
Do you have access to a 2D program such as Autocad? I could give you the flat pattern of the parts. If not, I could provide a drawing detailing dimensions. I don't have any plans to sell right now, sorry.
      03-02-2017, 02:03 PM   #13
STR8-6IX
Drives: RWD 528i N52
I doubt this will perform better then stock unless you are modified.
      03-03-2017, 08:33 AM   #14
Jayphil
Jayphil's Avatar
63
Drives: 535I xdrive 2011 (M-SPORT)
Looks very nice but also looks useless since the OEM air duct is the biggest restriction point and not the actual filter. Otherwise just throwing a K&N drop-in would do the trick without all the trouble you went into.
Still congradulation for you DIY skills and being different.
BMW 535I xdrive 2011 M-Sport with H&R Springs, Niche Form Wheels 8.5 ET35 / 10.5 ET35, Continental DSW06 245/35 & 285/30, JB4 Map 5, ER Downpipe, Megan Racing Quad Exhaust with Vibrant resonators, M5 Diffuser, Orange reflector shaved and removed xdrive badge.
