2010 2011 BMW 5 Series Forum F10 Vorsteiner V-FF 103 - 9 x20 / 10.5 x 20 - Tyre help |
12-28-2015, 10:14 AM | #1 |
Rep 1,161
i'm looking at getting a set of the vorsteiner flow forged V-FF 103s in 9x 20 ET 30 F and 10.5 x 20 ET 40 R.
but am undecided on tyres. options are 245/35/20 F 285/30/20 R 255/35/20 F 285/30/20 R 255/35/20 F 295/30/20R does anyone have any input for me please. I have looked at the following website for help: http://www.willtheyfit.com/index.php...0.5&offset2=40 looks good, but what is an acceptable difference from stock on the speedo error? if I go for the wider tyres its looking at just over 1% error. any advice.
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
12-28-2015, 11:46 AM | #2 |
Rep 14,522
245/35/20 F
285/30/20 R this is what i'm running on my stock 356's for the rear you could run a 295 since it's a 10.5" wide wheel.
12-28-2015, 12:12 PM | #3 | |
Rep 1,161
I'm thinking the wider the better, especially for the rear.
2014 M5
12-28-2015, 12:39 PM | #4 |
Rep 14,522
i mean that's what i'm running for my 20" setup. i don't know if a 255 is considered to wide on a 9" wide wheel? if anything a 255/35 would be a taller tire. now my 21" wheels i'm running 21x9.5 with a 255 but hopefully someone can chime in whether it's ideal to run a 255 on a 9" wide rim
12-28-2015, 01:10 PM | #5 | |
Rep 1,161
I think 255 is ok, as M5 wheels for the front are 9x20 and they use a 265/35/20 for the front
2014 M5
12-29-2015, 04:24 AM | #6 |
Rep 29,202
I got 255/35/20 on 20x9 in the front.
12-29-2015, 04:44 AM | #7 |
Rep 1,161
thanks,
think I will go with 255 F and 295 rear. or does it depend on the offset of the wheel also?
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold Last edited by Hasser; 12-29-2015 at 04:52 AM.. |
12-30-2015, 06:32 AM | #8 |
Rep 29,202
It might, front is no problem, but the rears might be. I've have ET46 in the rear, but 11" wide.
12-30-2015, 08:57 AM | #10 | |
Rep 1,161
why didn't you go for 295? I se that the difference between front and rear width is normally 30 ie. 245 - 275 255 - 285 265 - 295 - (M5)
2014 M5
01-01-2016, 08:07 PM | #12 |
Rep 88
Hasser..if you go with a 255/35/20 F 295/30/20R do you know how much taller that is over the stock tire? I know its wider, but how many inch's taller is the over tire? I want to run the same on my car. thanks
01-02-2016, 01:13 AM | #13 | |
Rep 1,161
9" ET 44 vs 10.5" ET40 Diameter 675.1mm 685mm Circumference 2120.9mm 2152mm Poke 70.3mm 93.4mm Inset 158.3mm 173.4mm Speedo error 0% -1.45% Reading at 30mph 30mph 29.57mph Reading at 60mph 60mph 59.13mph Ride height gain 0mm 4.95mm Arch gap loss 0mm 4.95mm and front 245/40/19 vs 255/35/20 8.5" ET34 vs 9" ET 30 Diameter 678.6mm 686.5mm Circumference 2131.9mm 2156.7mm Poke 74mm 84.3mm Inset 142mm 144.3mm Speedo error 0% -1.15% Reading at 30mph 30mph 29.65mph Reading at 60mph 60mph 59.31mph Ride height gain 0mm 3.95mm Arch gap loss 0mm 3.95mm
2014 M5
01-02-2016, 07:13 AM | #14 |
Rep 14,522
Those BMS lugs will look great with these wheels!
02-27-2016, 01:59 AM | #15 |
Rep 1,161
update here:
I've purchase the VFF-102 in Carbon Graphite for my AW ActiveHybrid 5. 20 x 9F with 255/35/20 non run flat M PSS 20 x 10.5 R with 295/30/20 non run flat M PSS hopefully get these installed by then end of March.
2014 M5
02-27-2016, 08:04 AM | #16 |
Rep 14,522
Awesome! post some pictures when you do!
03-01-2016, 01:45 PM | #17 |
Rep 29
Let us know if you experience any tire rubbing in the rear with 40et.
2014 550i MSport | 704 Suspension | HRE P40 | Michelin PSS | M5 Grilles | CQuartz Finest | 3M Crystalline | Coded |
03-22-2016, 10:44 AM | #18 |
Rep 1,161
wheels should be arriving on Thursday this week for fitment.
2014 M5
03-22-2016, 01:21 PM | #19 |
Rep 14,522
you got the BMS titanium lugs too if i remember?!
03-28-2016, 02:43 PM | #20 |
Rep 29
And the rubbing or no rubbing verdict is?
03-28-2016, 03:16 PM | #21 |
Rep 1,161
Wheels were sent to Germany for some reason by dhl. So not arrived yet.
2014 M5
04-11-2016, 10:55 AM | #22 |
Rep 22
