2010 2011 BMW 5 Series Forum F10 ISC N1 Suspension Installed! (No DIY) |
08-30-2020, 11:30 PM | #1 |
Rep 115
Drives: 2011 535i (6sp)
Finally got the car lowered and wheels/tires on!!
Suspension is ISC N1 Coilover. They are street comfort spec. I've had this setup on my old 325i so I knew for the most part what to expect. For this install, I had a shop do it as when I installed on my old 325, i was burning the midnight oil and I don't have a garage anymore either. They set the height perfectly at about a finger gap at both front and rear. Not slammed by any stretch but visibly lowered. The shop set the damping right in the middle of this 32-way setup. Obviously had the same shop align the car and the built-in camber plates included were helpful in getting great alignment with a lower setup. In terms of handling, this car is completely different from stock, non-sport. It hugs and hunkers down in tight corners and on/off ramps alike. The 535 in its stock form is a boat. This setup does make you almost forget you're in a two-ton car. As far as ride quality, it's definitely noticeably harsher and immensely firmer. At times it's somewhat too noticeable. When hitting uneven road patches, you definitely feel it. If ride quality is a large concern - I definitely recommend another setup. I don't mind too much but haven't done much exploring with the damping either. I'm sure I can soften it up a bit. The only problem is that you have to remove the rear speaker covers to access the damping adjustment slots. Wheels are VMR v705. Love a clean 5-spoke design and I think it really makes the car stand out. Tires are Bridgestone S001, 245/40-19. Absolutely love these tires. They will not break loose no matter how hard I've pushed! |
08-31-2020, 07:50 AM | #2 |
Rep 14,521
looks good bro!
08-31-2020, 10:55 PM | #3 |
Rep 115
Thanks!
Forgot to mention in the original thread - it's a manual transmission as well! |
