2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Finding Limits of N63 stock turbos....
      03-10-2017, 12:42 PM   #1
MissionPerformance
MissionPerformance's Avatar
Drives: '17 F31 340xi US Spec
The n63tu platform has proven to be a real underdog since we are seeing more and more 550i's with nearly M5 performance figures. Most are running Pure or Alpina turbos, so we set out to find the limits of what stock 2256s are capable of. Surprisingly, those two little turbos are capable of quite a lot. We started at 15psi, then to 17psi, followed by 20, 22 and finally 24.5psi. Yes the stock turbos were able to achieve nearly 25psi at reline. There is still some more room to go, and maybe 26psi is possible since WGDC was only at 57%, but we did start to feel the turbos approaching the choke point. Once these turbos FINALLY go and we find the breaking point (Most likely 25/26psi), we have our stage 1 set ready for a next challenge.
Here is the datalog pulled from the car on the way to the office. Car is running 100% e85, no 91, 50/50 meth-water, stock downpipes, stock intakes, stock fuel system. The HP figure is estimation for sure, but at 930kg/h per bank, the crank hp can be estimated at 690-710. Next week we will be strapping the car on the dyno and we will see what happens, but the numbers should be around 600whp.
To put things in simple terms, engine is a pump. The more air it consumes, the more power it makes. As a reference, stock F10 M5 makes peak HP consuming around 1600kg/h white this 550i is doing ~1850kg/h. Thats 15% increase. Not too bad for those little turbos.
One HUGE upgrade for N63 platform would be custom compressor housing and M5 intercoolers. Stock N63 charge pipe/housing output diameter is 40mm VS 52mm found on the M5.
http://www.datazap.me/u/missiontunin...3-6-9-10-11-14
      03-10-2017, 04:37 PM   #2
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
I looked up the N63 and N63tu turbos and they both are Garret MGT2256 turbochargers with the TU having 9 compressor blades of equal size as opposed to the n63 non tu's double blades, 5 large and 5 small.
Thats crazy how the tu units are moving so much more air than the non tu units. I'm sure us non tu'ers can swap to the tu turbos.
Are the M5 intercoolers and charge pipe/housing interchangeable with the N63/N63tu units?
      03-10-2017, 06:07 PM   #3
550Reasons
550Reasons's Avatar
Drives: F10 550i
how are you running 100% E85 ? Is it just in the tune as well or does it need a sensor or what ?
Also why still on stock downpipes ?
I would love to see you guys tune a TU with the new coming BMS intakes, some DPs, Alpina intercoolers.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      03-10-2017, 08:47 PM   #4
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
550 sleeper! Telling you put a 528i badge on it
IG: @bmwdoubles
      03-11-2017, 10:32 PM   #5
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
what about Dinan intercoolers? I have a set that I have not installed in my TU. along with intakes AR catted DPs and M5 CP cat back exhaust.
      03-20-2017, 11:36 AM   #6
STR8-6IX
Drives: RWD 528i N52
running that much boost, wouldnt it be best to upgrade the downpipe? probably the intake too.
FSociety3812.50
      04-07-2017, 09:48 PM   #7
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
what meth kit did you use?
      04-07-2017, 09:51 PM   #8
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
      06-09-2017, 02:33 AM   #9
_des_
Drives: 2011 550i
I don't think it would be a direct swap from non-tu n63 to n63tu turbos since they don't have diverter valves on the turbo.
Is it possible just to swap the center cartridge between the 2 into a non tu compressor cover? More less for the diverter valve usage?
      06-09-2017, 01:16 PM   #10
535_BiTurbo
ah thats right, I forgot about the DV
      06-09-2017, 01:19 PM   #11
535_BiTurbo
I need M5 intercoolers.
Will the M5 chargepipe fit a 550?
      06-09-2017, 08:40 PM   #12
flamelauncher14
flamelauncher14's Avatar
Drives: my neighbors crazy!
2009 Nissan GT-R  [10.00]
Hit me up once you develop a tune so I can blow my motor after the CPO warranty expires
Then I'll do the same to my 650i
Current: 2009 Nissan GT-R | 2012 Converted | Cobb Tuned | AMS Downpipes | Armytrix Exhaust | AFE Intakes
| Forgestar F14 + Pirelli P Zero 295/305
Past: 2011 550i ///M Sport | 2010 M6 Coupe | 2004 BMW M3 Convertible | 2003 BMW 330i
FSociety3812.50
