04-11-2020, 07:42 AM | #1 |
Rep 10
Help please
I have a 2011 bmw f10 550 xdrive. Can I put these tire size without messing up the xdrive?
255-40-20 front 295-40-20 rear |
04-11-2020, 10:22 AM | #2 |
Rep 697
Drives: 2013 535xi
No.
You could go 255/35/20 and 295/30/20 without problems although the back might be too wide unless your wheel width is 10" or more. You could even go with 255/40/20 and 295/35/20, but these tires are oversized (larger overall diameter) than a stock size. Do some research on the threads within this section, as there are many, many, many recommendations herein.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
Hendrichs230.00 |
04-11-2020, 10:28 AM | #3 | ||
Rep 10
04-13-2020, 03:12 PM | #4 | |||
Rep 29,202
Hendrichs230.00 |
04-13-2020, 04:07 PM | #5 | ||||
Rep 10
04-22-2020, 08:21 PM | #6 |
Rep 10
Hey y’all,
I just put on some 245/35/19 on some 19x9.5 with 10mm spacers in the front and I put some 285/35/20 on some 20x10.5 on the rear both with 35mm offsets and I’m running into some error codes is this normal? Is there a way I can remove the error codes and tune my speedometer to cope with the staggered offsets ? These went on an F10 535I I’m not having any running issues in the front or rear. Thank y’all for any information you can give ! |
04-22-2020, 10:23 PM | #7 | |
Rep 697
Drives: 2013 535xi
245/40/19 front and 285/30/20 rear.
04-23-2020, 11:15 AM | #8 | |
Rep 10
04-23-2020, 08:59 PM | #9 |
Rep 697
Drives: 2013 535xi
Sorry, I've never done coding or otherwise worked around error codes. I also think that your car won't look right since the rear tires are so much larger in diameter than your front. I'm curious if a 'professional' recommended your tire sizes, since they really are not well matched. Good luck!
