2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications LPFP upgrade
      04-27-2020, 02:49 PM   #67
BimmerHausPerformance
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
Does it work well? You need more testors? :-)
      04-27-2020, 02:51 PM   #68
95blkmax
Drives: '11 535 M-Sport
Originally Posted by jayster0966 View Post
It is a project that a buddy and myself undertook to provide real-time ethanol content in the fuel system of any vehicle. We use a GM ethanol sensor spliced into the main fuel feed to the motor. Board is a Arduino and programmed by my buddy. Case was 3D printed back then but we do use a pre-made case now.
Well it looks pretty dope!
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24
      04-27-2020, 03:42 PM   #69
jayster0966
jayster0966's Avatar
Drives: 2011 535i
Does work well. Great when you like to run mix blends like E30, etc..
We originally had a run of 15 units (all sold now) but it took a while to sell. We do have components to make about 10 more in stock but there has not been enough interest at this point and time.
We can do another run (as all have to be hand assembled and programmed) if there is enough interest. (individual orders possible as well)
PM me if interested so we do not clog up this thread with another topic.
      04-27-2020, 04:01 PM   #70
513
How much? Forget it we are on page 4... It is time for a distraction. Besides, reading you e levels is important when you are doing a lpfp, somewhat related!!
Do you have pics of the new housing?
      04-27-2020, 04:37 PM   #71
jayster0966
Drives: 2011 535i
Pics of the kit. Case can be had with or without tabs.
$180 shipped lower 48 states
      04-30-2020, 03:29 PM   #72
Trainwreck914
Trainwreck914's Avatar
Drives: BMW F10 F15 E39 E90 E53
Originally Posted by Trainwreck914 View Post
Nothing in particular that I'm trying to "get to". I guess I just got motivated seeing it as an "upgrade". And preventative maintenance for $100. I don't typically get stranded. But would hate if I was. Hpfp goes out car will go into limp mode. LPFP goes and your a sitting duck. Car has 127k on it now so I figured sooner than later. I went with the lp450 ends in 267. I have the newest version jb4 installed and figured it might be cool to do the whole e85 thing. But I'm second guessing using that in my car. Lots of mixed reviews/myths about it.
Guess I spoke to soon. Got on the highway and car went into limp mode and shut down. Would crank but would not start. Left me stranded. Trooper made me get a tow. Just filled up yesterday so had a full tank. I have jb4 so some codes are due to that.
      04-30-2020, 06:25 PM   #73
Trainwreck914
Ahhh. Just user error. Pulled the pump and found the supplied fuel hose had popped off. Silly me I thought just by heating the tip and sliding it on, that it would stay on. The kit did come with clamps. And I did not use them. So take it as a lesson. USE THE CLAMPS! Installed the clamps and put the pump back in. Running like a champ now. Hey. I can do this in like 30 min now
95blkmax212.50
      04-30-2020, 10:54 PM   #74
95blkmax
Man what a save!! I appreciate you sharing your successes and your lessons too.
Is there any chance you could share a log? Maybe against a before log on the same gear to compare apples to apples on this LPFP upgrade?
      09-25-2020, 03:02 PM   #75
Gjohnson7
Gjohnson7's Avatar
255
Drives: 11' BMW 535i, 12' Lexus RX350,
2011 535i  [0.00]
Ok, time for an upgrade. I just picked up the High pressure version f90000274. Should be here Sunday and I will swap in.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771
MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster.
      12-17-2022, 03:04 PM   #76
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
I grabbed the 295 version. It's the 274 but without an internal check valve. Flows more for the same current draw. Only downside is that you might get a long crank when starting it cold, but honestly it's not really a huge deal since it helps build some more oil pressure anyhow during crank, which is kind of a pro. If it bothers you a lot, could always splice in a full flow check valve somewhere in your fuel line. I just used a brass drift and a deadblow to slowly bang the ring off and on, but a proper tool would definitely make it FAR less time consuming and tiring.
Heads up for those doing the install. I had less than a quarter tank left and it was still almost too much gas in the tank. Thankfully wasn't overflowing, but still needed to really dip your hands into gas. The fuel line that is posted also is too long. Needs to get about a half inch taken off both sides, otherwise the bend is too tall and the hat hits it. I got lazy and didn't want to take out the LPFP, yank off the line, and trim, so I just trimmed the little nubs on the hat that were hitting it. They're not used for anything in our cars as it's just a dummy plug. Other solution is to either source a proper length tube (about 5-6 inches) or get a rubber one that you can trim to length as needed.
Overall a pretty straightforward upgrade.
Edit:
Nubs I'm talking about (see attached photo). Likely used for a second LPFP plug for cars that run dual pumps.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      12-18-2022, 09:35 PM   #77
95blkmax
Edit:
thanks for the share. I never knew that was the difference between the -274 and the -295! That makes more sense now as to their specs.
And yea when I did it on mine I waited for the low fuel light to turn on. Maybe about 1/8th of the tank. At that point it was perfect to do it. This is the install vid I made for that https://youtu.be/QgmLcQigkUo. You can see how low the level of fuel was inside the tank.
