2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Cornering Lights
      04-03-2016, 10:59 AM   #23
Chili Palmer
Master Of My Domain
Drives: 2015 650i Gran Coupe
I'll give that a try - Thanks.
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
      04-16-2016, 04:06 AM   #24
Apples12
Drives: 520D LCI auto
Is there any way of getting cornering lights on the LCI xenon units? And/or adding fogs to behave as cornering lights?
      04-16-2016, 07:58 AM   #25
DDD31
DDD31's Avatar
1646
Drives: 24 M3CS, 95 E320, 85 300CD
LCIs with xenon headlights come with cornering lights as standard. They only activate when the headlight switch is in auto and either the wheels are turned, the turn signal is activated or car is put in reverse.
      09-23-2018, 10:12 AM   #26
Dudes
Drives: 2013 535i xDrive
Philips diamond vision H7 bulb in 5k > Sylvania zxe. Take my word for it, I have the scrapes all over my hands to prove it.
I installed the zxe bulbs and while they were an upgrade over stock I wasn’t satisfied with the look. I realized I had the philips diamond vision bulbs already installed as the high beam bulbs in my winter vehicle (2006 Volvo XC90) so knowing that there hasn’t been much use with those bulbs as they were installed about a year ago and I can count how many times I’ve used the high beams on one hand... I decided to swap them out with the zxe’s and believe me when I tell you they are much better and much closer in matching the halos & xenon bulbs. Just take my word for it so you don’t have to go through the trial and error like I did! You’re welcome in advance!
It would always just irk me that whenever I would corner or put the car in reverse that the halogen yellow bulb would light up and not match the halos or xenons right next to it. I personally don’t mind the contrast between headlights and fog lights but for bulbs not matching right next to each other just bothered me but now that problem is solved.
      01-05-2019, 02:05 PM   #27
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
I am going to look into those Philips bulbs. From my past experience, bulb matching (hue and temp) was always difficult. Thanks for sharing the info.
      01-05-2019, 06:15 PM   #28
starlights
Drives: G05 50i
I have the Philips Diamond Vision bulbs right now but they are not bright at all. Will be going back to high power LEDs soon as I have sourced the 6Ohm resistors to mitigate the dash warning.
Edit: I had installed 12000 Lument LEDs in there that I liked a lot but they threw repeated warning in the Dash.
      01-05-2019, 11:20 PM   #29
TTG
TTG's Avatar
Drives: M340
Throw some 6K halogen bulbs in there and call it a day......Can't believe this has been discussed for 2 pages
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
