2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 Charge pipe size?
      05-30-2017, 12:55 AM   #1
_des_
Drives: 2011 550i
My Passenger side charge pipe seems to have an ever so small cut in it.
So I want to have the hose replaced/changed. Before removing the clamps from the intercooler. Does anyone know the inlet size for the charge pipe or the Turbo side? I I intend on replacing the charge pipe with couplers on each end and a hard pipe in between. Similar to the m5 setup.
I know the clamp for the intercooler is 72mm(2.83") So I'm assuming the inlet is 2.75". But guessing on the turbo outlet size, I Think it is 2.0"
I know they dont make any options like they do for the m5 (https://www.x-ph.com/burger-tuning-b...th-meth-bungs/)
Let me know if anyone has anymore info on this, or has it been done before. Or is it a waste of time and try to source a stock charge pipe.
Thanks in advance.
      05-31-2017, 05:08 AM   #2
_des_
Drives: 2011 550i
For those that are interested.
The intercooler side is just below a 2.5". Closer to a 2.25" but a 2.5" coupler with a clamp will seal.
On the turbo charger side its 1.75"
Im still going to play around with the idea of changing it out. We will see.
      06-02-2017, 05:09 PM   #3
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Will the g30 intercoolers work on the n63?
      06-02-2017, 05:21 PM   #4
_des_
Drives: 2011 550i
Hmm no idea. Are they supposed to be better?
      06-21-2017, 10:22 AM   #5
535_BiTurbo
they look larger
      06-21-2017, 09:17 PM   #6
SchillerM
Drives: 11' 550i, '00 M5, '11 E90 335i
I don't think there is room in there for the new ICs. They appear to be closer to M5 sized. The Stock N63 is tight fit, the Alpina/Dinan ones are ~25% larger and take up all the extra room.
The N63Tu Alpina ICs are probably the most ideal setup due to the molded/cast ducting in stead of chargepipe.
Matt
2011 Space Grey 550i - Eisenmann exhaust, ACS Springs, Dinan Intercoolers, Intake, & Stage 5 tune
2011 Space Grey 335i - M Performance exhaust - Wifes
Past: 2000 Avus Blue M5 - Dinan exhaust, flywheel, & tune 180k+miles
      06-22-2017, 12:59 AM   #7
535_BiTurbo
what about M5 chargepipes and intercoolers on the 550?
