2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 20" wheels - How Wide in the Rear?
      01-18-2012, 12:52 AM   #1
AgsWin
AgsWin's Avatar
200
Drives: 2022 Frozen Dark Grey M3
Cant decide what is the best option for a set of Forgestar wheels. I have heard 20x9 in fronts and 20x10.5's in rear. Is that the ideal set up or are some people running 20x11 in rears without problems?
      01-18-2012, 01:38 AM   #2
enzeru
is writing a message
enzeru's Avatar
Indonesia
12
Drives: F10/GL500
Im running 11.5 rear without problem, so 10.5 should be fine as long as you have the right offset and tire size
      01-18-2012, 10:12 AM   #3
remmib
remmib's Avatar
Norway
1571
Drives: 2013 F10 520d M-Sport
If your not doing wider tires than 285, I see no piont going wider than 10.5" rear wheels.
      01-18-2012, 10:54 AM   #4
AgsWin
AgsWin's Avatar
200
Remmib, thanks for your input. I talked with LACASTER and I think I am going to go with 20x9 in fronts and 20x10.5 in rears. What size tires should I run with this set up?
      01-18-2012, 12:34 PM   #5
remmib
remmib's Avatar
Norway
1571
You can go with the oem size 245/35/20 + 275/30/20,
but many puts on a little wider 245/35/20 + 285/30/20
or 255/35/20 + 285/30/20.
      01-19-2012, 11:42 AM   #6
AgsWin
AgsWin's Avatar
200
I was just informed that the wheel I want comes only in 20x10 or 20x11, what do you recommend if I am going to be on H&R and have an M Sport F10?
      01-19-2012, 12:23 PM   #7
Andy@MORR
Drives: E92 M3
It really depends on what you're trying to achieve with the car. Running anything larger than a 20x10" on the F10 is honestly just for bragging rights, as their is zero added benefit from going with a 10.5" or 11" rear. The only thing you'll gain, is added weight, which is a negative.
You're limited by your rear tire selection, and a 20x10" fits any tire you could want to run in the rear if you plan to stay within the maximum tire widths recommended for an F10.
If you have a serious need to add rear traction, a different selection of tires, or a wider tire can help, but on this platform, adding a massive rear tire and a massive rear wheel does nothing but hurt the overall feel of the car with an unnecessary stagger and added rotational weight.
Again, it depends on the overall goal you're going for, but to increase the wheel size, and still keep the car feeling quick on it's feet and increase the vehicles responsiveness and overall dynamics, go for a light wheel in a 20x9" & 20x10" set-up. That's what we run on F10's, and have had nothing but great feedback so far. A 20x10.5" is fine in the rear too.
Hope this helps!
Here's one of our 20x9" & 20x10" set-ups on an F10, running a 285/30/20 out back:
- Andy
      01-19-2012, 06:33 PM   #8
Park828
Drives: Man
setup looks pretty amazing! with that setup no rubbing at all? if it makes any difference i have m sport with dynamic handling + integral active steering + Dynamic drive and plan on lowering the car a little bit too. tires will most likely be michelin pss in the sizes you recomended.
thank you!
      01-23-2012, 10:32 PM   #9
Andy@MORR
Drives: E92 M3
thank you!
Zero rubbing on that set-up, on that F10. But remember, offsets have way more to with it than the widths do. Picking the right offset in combination with the right width allows you to optimize the set-up for your car.
This car is slammed on KW Variant 3 coilovers, and experiences no rubbing, so just make sure whichever wheel company you purchase from picks picks good widths for you, but more importantly, picks good offsets for the F10 platform and your particular end goal for the car.
Hope this helps!
- Andy
      01-24-2012, 05:51 PM   #10
ModBargains IV
ModBargains IV's Avatar
Drives: e92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, La Habra, CA 90631
You can go up to 11.0 in the rear I think, but 20x10.0 is what usually most of my F10 customers get.
      01-25-2012, 10:21 AM   #11
GTR-Dad
Driver
GTR-Dad's Avatar
Drives: 2012 M5 - DCT
Canadian F10M5's are listed as coming with 20x10.0 shod with 295/30 R20's.
      01-30-2012, 04:19 PM   #12
commaps188
Drives: 335i
what are the correct offset if one is planning to slam the F10
20x10 or 20x11, and suggestion?
Thanks
      02-13-2012, 04:14 PM   #13
DentalBoy
DentalBoy's Avatar
50
Drives: 2016 M6 Gran Coupe
Has anyone tried 295 with 10.5 wheels. I am buying wheels soon and the suggested is 285/30/20 I want to avoid the stretched look and thought a touch wider would help??
      02-13-2012, 04:34 PM   #14
LACSTER
Drives: Hybrid
285 is perfect for a 10.5 wheel. You can check out the specs of the tire on
their website for specs on wheel fittings. Most 285 can mount on 9.5 to 11 width.
Kevin
      02-14-2012, 05:22 PM   #15
DentalBoy
DentalBoy's Avatar
50
Thanks Kevin, I appreciate the input...
      01-23-2014, 03:14 PM   #16
Don Juan
Don Juan's Avatar
Drives: 2020 X7 40i, 2020 I3s Bev
or you can run 195/30/20 in the rear which i think is the perfect size as remmib
My setup is 20x8.5 with 255/35/20 and 20x10 with 285/30/20.. I would have prefer the 295s as they have a little more shoulder to protect the rim...but too late..need to wait until it the tire wears off
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims
Retired
2020 X7 MSport 40i
2020 I3s Bev
      01-23-2014, 10:01 PM   #17
william_rhettb
Drives: 2011 550i
I am going with the OEM 312 style 20" rims, which are as follows:
Fronts are 8.5x20 ET:33, tire recommendation 245/35-20
Rears are 9x20 ET:44, tire recommendation 285/30-20
Should I use spacers? If so, what size? Will the standard 10mm front, 15mm rear work?
Thanks for your help
ss2marc10.50
      01-23-2014, 11:30 PM   #18
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
332
Drives: 2020 M8 & 2022 X& M50i
Front can easily take a 10 mm
Rear can easily take 18 mm
And still be conservative
Correct me if I'm wrong
      01-26-2014, 11:03 AM   #19
///M ARMY
Drives: F90
You can run a 295 with a 11 rear. That's what I'm running
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      02-03-2014, 03:31 PM   #20
fharose
Drives: 2011 550i
Hi Folks,
I recently installed 20x9.5 in front and rear which came off my old 5 series. Will there be any issue running a standard setup (handling, suspension, rubbing etc)? The current tire size is 245/35/20.. Can I install 275/35/20 on the rear with this set ?
I get humming sound and the shop recommended to change the front tires.
I need some help here...
Thanks,
Ferry
Ferry
2011 550i
CF grille, 20" Matte Blk HR6 wheels, Llumar CTX tint (17% rear, 35% front)
      02-03-2014, 04:36 PM   #21
MELLOWYELLOW06
332
What are the offsets? Without that, its hard to tell.
I believe the older 5s had a lower offset but with only being 9.5 out back, you may be fine.
      01-28-2015, 12:10 AM   #22
c21sam
Drives: 2018 BMW 530e Xdrive
I have a new 2015 528i and I am buying new 20" wheels. The front's are 8.5 " with 35 mm ET The rears are 10" with 40mm ET. I want to run 245/40 in the front and 275/35's on the rear will this be a problem? I would really appreciate any feedback
