2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes E61 wheels on a F11??
      12-10-2012, 01:16 PM   #1
SCZ4
Drives: F11 525d M Sport & Z4M
Anyone done this?
Was considering getting some Eibach spacers for my F11, 12 or 15mm, the wheels just sit far too inside the arch. Then I thought how much I loved my 172M alloys on my E61 550i, if I was fit those to my 525d then it would effectively space the wheels 15mm due to the different offsets and arguably have a better looking wheel!. uestion is, would extending the wheels out by 15mm rub or still clear the arch?
      12-10-2012, 03:21 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Have you looked here, at offsets against rim widths?
http://felgenkatalog.auto-treff.com/
You can then do a bit of math for each wheel and see where it fits in the F10/F11 working envelope. You don't say what rim widths you have, but I see the F10/11 351 (8.5" x 19", ET33) having a bigger offset, so your 172 (8.5" x 19", ET18 ?) will already be further out by 15mm, without spacers.
I assume you are changing tyres to get the F11 rolling circumference, (RC) as the E61 is down a size on the aspect ratio, compared to the F11.
HighlandPete
PS: I think I'm reading you wrong... you have the 172 wheels, and/or you want to space the F11 wheels by up to 15mm? Not sure what clearance you'll have, I'd look at the largest sizes available as OEM, and see where the outside dimension comes.
Pete
      12-11-2012, 02:43 AM   #3
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Well, here's the e60 172M on a F10. I assume it got the wider rear.
More pics in this thread.
http://f10.5post.com/forums/showthre...&highlight=172
      12-11-2012, 03:04 AM   #4
SCZ4
Pete
Yeah, basically I've worked out putting the 172's on my F11 will make them stick out another 15mm, so just wanting to know if they will clear. My winters stick out 7mm more and look to have plenty of clearance still.
      12-11-2012, 03:04 AM   #5
SCZ4
Looks good... I don't see a link though.. do you have it handy?
      12-11-2012, 06:44 AM   #6
remmib
remmib's Avatar
Norway
1568
Ops, forgot the link, here it is.
      08-25-2015, 09:55 AM   #7
K6MHX
Drives: F11 M-Sport
Sorry for the Thread revival but as I haven't a clue about wheel fitments, I'd thought I best ask before purchasing.
My mate has some aftermarket wheels that he bought for his E61 estate but never fitted, they are; Front = 20x9 ET20 and the Rear = 20x10.5 ET25.
The rear do have more of a concave than the fronts.
So 2 questions,
1. would they fit?
2. If they fit, what size tyre (Tires) would I need?
The car is currently at standard ride height (m-sport) but I am looking at fitting coilovers in the not to distant future.
      08-25-2015, 01:22 PM   #8
remmib
remmib's Avatar
Norway
1568
So 2 questions,
1. would they fit?
I good fitment for the f11 is et25 in the front and et40 in the rear, so these wheels will stick out 5mm in the front and 15mm in the rear.
