12-23-2023, 02:19 AM | #1 |
Rep 5
Won't go above 161mph
Hi all,
Asking a question I've seen before but have never seen a legitimate answer to. I had never done a top speed run on my car before until accidentally the other day. I've got a 2014 550i non m-sport. Passed a trooper at around 105mph and decided to run when he turned on the lights. At 161 exactly, the car noticably stopped accelerating (felt it and the rpms stopped increasing). Was in 6th gear around 3.5k rpms when the car hit what felt like a brick wall. Running vrsf downpipes and bm3 stage 2 tune. Speed limiter is turned off in the tune settings. It felt like the car had a lot more in it, which would make sense when stage 2 550's are dynoing in around 580whp. I'm located in a colder climate (about 25-35 degrees farenheit at the time) and the car throws on the coolant light occaisonally due to the ambient temp. Unsure if that might contribute. Also odd that the speedometer stops at 160 and thats where the car stops. HUD also shows 161. I've seen heatsync tuned 550's do 180+ on stock turbos so I know that the car can at least go over 160 on a bootmod tune. Any insight would be fantastic! Thank you! |
12-23-2023, 07:39 AM | #2 |
Rep 174
You forgot to add "accidentally the other day in the middle of the snow storm while saving a puppy " 🤡
12-23-2023, 11:24 AM | #3 |
Rep 3,020
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
"Asking for a friend..."
12-23-2023, 12:40 PM | #4 |
Rep 2,591
Decided to run?
The fuck is wrong with you. Shame on you.
2015 BMW 535xi
zrile91.00 |
