01-23-2013, 10:02 PM | #45 |
NorCal BMW Specialists
49
Rep 210
You the man, that is a good call on the 550GT. I've been trying to source the M550D bar, but the 550GT looks to be the largest.
01-23-2013, 11:26 PM | #46 | |
Rep 282
Are u trying combine M5 bar (front) and 550 GT (rear) next? |
01-24-2013, 12:02 PM | #47 |
Rep 8,801
I am going to try the front M5 bar on my 2013 535xi.
Joe@ptech is going to try out the F07 550 bar in the rear since its 18mm which is 4mm bigger than stock. Hopefully he has good news for us. Alan
01-24-2013, 12:57 PM | #48 |
49
Rep 210
Yes, ordered the F07 bar today. So we should have news within the week. If all goes well, we are happy to host a group buy for the combined front and rear bars.
01-24-2013, 03:20 PM | #49 |
Rep 282
01-24-2013, 03:29 PM | #50 | |
Rep 621
Thanks for trying out for 535xi folks Please keep us posted!! |
01-24-2013, 04:50 PM | #52 |
49
Rep 210
01-29-2013, 12:11 PM | #53 |
Rep 8,801
F10 M5 sway bar shipped! I might attempt to install it this weekend
Hopefully its good news for us Xdrive guys that is looking for tighter handling. Alan
02-02-2013, 01:25 AM | #54 | |
49
Rep 210
02-02-2013, 11:42 AM | #55 |
Rep 8,801
Confirmed!! The M5 front sway bar is a direct fit for my 2013 535xi!!
Visually it is much thicker and so far the car feels more planted and tight. Will report back after some more driving but so far its worth every penny! This a big news for the F10 community lusting after better and sportier handling! Next up...550GT rear sway bar after Joe confirms 100% it fits. Alan
02-02-2013, 03:58 PM | #56 |
Rep 8,801
All I have to say is wow and everyone must do this. This is how the car should have came stock. My car has DDC and ACS springs and I am in sport mode 99.9% of the time. Before the M5 sway bar I would rate the handling of my F10 a 4 or 5 out of 10 at best compared to my previous E46 and E90 on coilovers but now its a solid 7.
The suspension just feels tighter and more solid up front and you notice it this when going over bumps and uneven roads. The car is flatter during turns and the steering feels alittle more direct/precise during high speed lane changes. Before I would anticipate the roll/sway movement but now the car just points to where you want it. It isn't a track car by any means but that wallowing feeling is pretty much gone or barely noticeable anymore. Nothing negative about doing this mod at all so far. Very pleased. Alan
02-02-2013, 04:57 PM | #57 |
49
Rep 210
Sweet, thanks for the update. We are happy to host a group buy for a discount on these parts for anyone that is interested. I hope to have the F07 bar this coming week.
02-02-2013, 08:50 PM | #58 | |
Rep 282
Joe, Can you host a group buy M5 front bar and F07 rear bar (assuming it works)? |
02-02-2013, 09:20 PM | #59 |
Rep 8,801
Ride quality did not suffer at all IMO. Drove around all day and could not be happier with it.
The M5 part # is 31352284460 It comes with the bushings already mounted on the bar. You reuse your existing bolts and endlinks. The install is a breeze. Once the underbelly pan is off there's only 6 bolts to remove the bar. You can do it easily yourself on ramps or let your shop do it. They should not take more then 20-30mins tops. Alan
02-02-2013, 10:56 PM | #60 | |
Rep 282
The M5 I test drove was very flat. Thanks |
02-02-2013, 11:21 PM | #61 |
Rep 1,066
Drives: 2015 X5 50i M Sport
We need a group buy now!!!
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
02-03-2013, 08:05 AM | #63 |
Rep 8,801
Look at reamoem.com and start comparing part numbers. If your car shares any part numbers as the 535/550 when the M5 front bar will fit your car too.
Looking at the 528i it shares the same front sway bar as my 535 if you have the ddc/edc shocks so safe to assume the M5 bar will fit. No gurantees though but I'm willing to bet it does. Alan
02-03-2013, 02:02 PM | #64 |
49
Rep 210
As soon as I can confirm the F07 rear bar works, which I'm pretty sure it will....we can host a group buy for everyone to save on these bars. We can ship anywhere in the States.
02-03-2013, 02:13 PM | #65 |
Rep 1,066
By reading this thread, M5 front bar fits both non-xi and xi models but M5 rear bar does not. Will F07 bar fit RWD 550i?
2019 Cayenne Turbo
02-04-2013, 11:18 AM | #66 |
Rep 8,801
^^Joe@ptech is going to find that out real soon
Now with the rear bar. Turns out on the 535 theres several sizes that the car comes with depending on options and if its RWD or AWD. 535i standard rear bar is 13MM 535i Msports rear bar is 14MM 535xi standard rear bar is 14MM 535xi with EDC/DDC rear bar is 15MM I did not check this for the 528 or the 550 but you can easily do it with realoem.com Since my car comes with a 15MM rear bar I will go with the 18MM F07 550GT's rear bar for a 3mm increase. Looks like you will also need to purchase new bushings with bigger internal diameter to hold the thicker bar. Hopefully thats it. Alan
