2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Vorsteiner V-FF 103 - 9 x20 / 10.5 x 20 - Tyre help
      12-28-2015, 10:14 AM   #1
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
i'm looking at getting a set of the vorsteiner flow forged V-FF 103s in 9x 20 ET 30 F and 10.5 x 20 ET 40 R.
but am undecided on tyres.
options are
245/35/20 F
285/30/20 R
255/35/20 F
285/30/20 R
255/35/20 F
295/30/20R
does anyone have any input for me please.
I have looked at the following website for help:
http://www.willtheyfit.com/index.php...0.5&offset2=40
looks good,
but what is an acceptable difference from stock on the speedo error?
if I go for the wider tyres its looking at just over 1% error.
any advice.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      12-28-2015, 11:46 AM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
245/35/20 F
285/30/20 R
this is what i'm running on my stock 356's
for the rear you could run a 295 since it's a 10.5" wide wheel.
      12-28-2015, 12:12 PM   #3
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Originally Posted by lsturbointeg View Post
245/35/20 F
285/30/20 R
why not 255 for the front?
I'm thinking the wider the better, especially for the rear.
2014 M5
1999 E38 728i -sold
M235i - sold
      12-28-2015, 12:39 PM   #4
lsturbointeg
i mean that's what i'm running for my 20" setup. i don't know if a 255 is considered to wide on a 9" wide wheel? if anything a 255/35 would be a taller tire. now my 21" wheels i'm running 21x9.5 with a 255 but hopefully someone can chime in whether it's ideal to run a 255 on a 9" wide rim
      12-28-2015, 01:10 PM   #5
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Right I see your point. Thanks.
I think 255 is ok, as M5 wheels for the front are 9x20 and they use a 265/35/20 for the front
2014 M5
1999 E38 728i -sold
M235i - sold
      12-29-2015, 04:24 AM   #6
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
I got 255/35/20 on 20x9 in the front.
      12-29-2015, 04:44 AM   #7
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
thanks,
think I will go with 255 F and 295 rear.
or does it depend on the offset of the wheel also?
2014 M5
1999 E38 728i -sold
M235i - sold
      12-30-2015, 06:32 AM   #8
remmib
remmib's Avatar
Norway
1569
thanks,
It might, front is no problem, but the rears might be. I've have ET46 in the rear, but 11" wide.
      12-30-2015, 08:12 AM   #9
PR_F10_535
PR_F10_535's Avatar
Drives: 2011 f10 535i
255 & 285. I have the same rims but my fronts r 245 & I regret not getting 255 but the rears r perfect w/ 285
      12-30-2015, 08:57 AM   #10
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
thanks.
why didn't you go for 295?
I se that the difference between front and rear width is normally 30
ie. 245 - 275
255 - 285
265 - 295 - (M5)
2014 M5
1999 E38 728i -sold
M235i - sold
      12-30-2015, 08:58 AM   #11
PR_F10_535
PR_F10_535's Avatar
285 fit perfect for my 1st set of vorsteiner wheels so I kept it the same on my 2nd set
      01-01-2016, 08:07 PM   #12
m3racing
m3racing's Avatar
94
Drives: 2023 M3 Comp, 2022 F150 Shelby
Hasser..if you go with a 255/35/20 F 295/30/20R do you know how much taller that is over the stock tire? I know its wider, but how many inch's taller is the over tire? I want to run the same on my car. thanks
      01-02-2016, 01:13 AM   #13
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
this is comparison for OEM rear 275/35/19 vs 295/30/20
9" ET 44 vs 10.5" ET40
Diameter 675.1mm 685mm
Circumference 2120.9mm 2152mm
Poke 70.3mm 93.4mm
Inset 158.3mm 173.4mm
Speedo error 0% -1.45%
Reading at 30mph 30mph 29.57mph
Reading at 60mph 60mph 59.13mph
Ride height gain 0mm 4.95mm
Arch gap loss 0mm 4.95mm
and front
245/40/19 vs 255/35/20
8.5" ET34 vs 9" ET 30
Diameter 678.6mm 686.5mm
Circumference 2131.9mm 2156.7mm
Poke 74mm 84.3mm
Inset 142mm 144.3mm
Speedo error 0% -1.15%
Reading at 30mph 30mph 29.65mph
Reading at 60mph 60mph 59.31mph
Ride height gain 0mm 3.95mm
Arch gap loss 0mm 3.95mm
2014 M5
1999 E38 728i -sold
M235i - sold
      01-02-2016, 07:13 AM   #14
lsturbointeg
Those BMS lugs will look great with these wheels!
      02-27-2016, 01:59 AM   #15
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
update here:
I've purchase the VFF-102 in Carbon Graphite for my AW ActiveHybrid 5.
20 x 9F with 255/35/20 non run flat M PSS
20 x 10.5 R with 295/30/20 non run flat M PSS
hopefully get these installed by then end of March.
2014 M5
1999 E38 728i -sold
M235i - sold
      02-27-2016, 08:04 AM   #16
lsturbointeg
Awesome! post some pictures when you do!
      03-01-2016, 01:45 PM   #17
RKtect
Drives: 2014 BMW 550i M Sport
update here:
Let us know if you experience any tire rubbing in the rear with 40et.
2014 550i MSport | 704 Suspension | HRE P40 | Michelin PSS | M5 Grilles | CQuartz Finest | 3M Crystalline | Coded
      03-22-2016, 10:44 AM   #18
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
wheels should be arriving on Thursday this week for fitment.
2014 M5
1999 E38 728i -sold
M235i - sold
      03-22-2016, 01:21 PM   #19
lsturbointeg
you got the BMS titanium lugs too if i remember?!
      03-28-2016, 02:43 PM   #20
RKtect
And the rubbing or no rubbing verdict is?
      03-28-2016, 03:16 PM   #21
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Wheels were sent to Germany for some reason by dhl. So not arrived yet.
2014 M5
1999 E38 728i -sold
M235i - sold
      04-11-2016, 10:55 AM   #22
NW535
Drives: 2015 535 M-Sport
Just got my custom finished Vff-103 installed with the 255/295 combo. Fit is perfect with no rubbing. I will be posting some pics soon.
