2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Rear Tires 2011 550i
      03-27-2019, 06:54 PM   #1
CarlosER16
Drives: BMW 550i
I really dislike the rubberband look of my current tires. Looking for a bit more cushion. Currently have 275/30/20 on my rear. Do you think I could jump to 275/40/20s? Asking for a friend...
ocas233.50
      03-27-2019, 08:33 PM   #2
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
A simple tire size calculator should give you the answer you need....they can easily be found by typing "tire size calculator" in a google search box.
You need to compare the rear and front axle overal rolling circumference and diameter...they should remain within 3% (+/-) of each other to prevent ABS/traction control/odometer/speedometer and AWD system (if so equipped) issues.
You may also want to check if there will be any suspension rubbing or too much "poke" ( a higher wheel aspect ratio from 30 to 35 shouldn't cause this issue...but I'd definitely check going from 30 to 40, though). Here's a good site for checking the aforementioned: www.willtheyfit.com
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      03-28-2019, 12:55 AM   #3
CarlosER16
Drives: BMW 550i
That was a great help, thanks a bunch!
      03-28-2019, 10:14 AM   #4
Qsilver7
Qsilver7's Avatar
      03-28-2019, 02:53 PM   #5
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
other's have switched from 20's to 19's as well
      03-28-2019, 04:47 PM   #6
agentorange
Drives: 328d
19" wheels and suitable boots for the win.
Tags
tire 20s, wheels, wheels 20
