2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Cheap EBay Strut Brace
      02-02-2020, 07:07 PM   #45
ziekxq
Drives: 2011 535i xDrive
I ordered mine too... I just hope spool can come out with ram style intake soon so I don't have to worry about blocking intake with the bar.
      02-02-2020, 08:05 PM   #46
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
Originally Posted by BrowBMW View Post
That looks nice, like the polished cross bars. Fair warning - that is going on my to-do list!
BTW, I'm going to do the oil cooler. I will install an aftermarket cooler, and send out the OE cooler to get polished. ;-)
Pic of engine bay from left-front.
      02-03-2020, 10:19 AM   #47
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Originally Posted by John H. View Post
@Unspec, Yes. Use a quality bit that cuts well. Also, be easy with the tap, I had broke one in the process. Some tools and parts used...
1.). M8x1.25 Helicoil kit, stainless inserts,#5546-8, NOS(New Old Stock) USA Made, $18 - eBay, stitapandtoolsupply
2.). Dewalt drill bit, , 21/64, item #93021, $5 - Lowe's
3.). T-handle tap wrenches, 3 pieces, item #38560, $9 - Harbor Freight
4.). Aerosal air duster spray, remove shavings from drilled holes, $2 - Micro Center
5.). Loctite Blue - for strut mount bolts.
6.) Brake cleaner -clean up area of oils.
7.) WD40 - For tap use and inserts installation.
Just finished the install. No hood adjustment needed. Came out tits.
Interesting that you used loctite for the bolts but none for helicoil. I know you don't need to, but you run the minor risk of the loctite messing with your helicoil when you undo the bolt. I plan on putting some loctite red on my helicoils when I do this. WD40 works well enough, but I'm probably going to go with a dedicated metal lubricant.
How deep did you drill?
Thanks for the detailed info break down!
2015 BMW 535xi
ISTA VM Setup/Tutorial
      02-03-2020, 05:12 PM   #48
John H.
John H.'s Avatar
Good point, and I considered red on the inserts; however, I felt the inserts are strong enough without it. Used blue because of the re-use of the bolts.
Deep enough for the insert to seat. I used blue painters tape to mark off depth on the drill bit.
      02-04-2020, 09:17 AM   #49
Unspec
Unspec's Avatar
1300
They're definitely strong enough without the red, I just like loctite
2015 BMW 535xi
      02-04-2020, 03:40 PM   #50
John H.
John H.'s Avatar
If you install the new updated bolts w/torx head, there will be factory locking adhesive on the threads. It is yellowish, and on the first 4 or 5 threads. Since I re-used those bolts, and have lost the adhesive, I applied the blue Loctitie.
Let me know how it turns out.
      02-12-2020, 10:11 PM   #51
John H.
John H.'s Avatar
Just picked up the oil cooler from the polishing shop. Looks purdy.
      02-12-2020, 10:15 PM   #52
BimmerHausPerformance
BimmerHausPerformance's Avatar
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
Dude, do they always throw in some sort of dried meat? Looks good.
John H.230.00
      02-13-2020, 07:52 AM   #53
John H.
John H.'s Avatar
Lol. Few days ago, my boy Norman smoked a batch of premium meats. Picked it up in the early morn, 2 dozen bags. Mods with beef jerky, that's how John H. rolls.
      02-13-2020, 06:28 PM   #54
513
What is the difference between that oil cooler, and this one?
2011 F10 S55 6MT
Website Insta @bimmerhausperformance YouTube
      02-13-2020, 07:42 PM   #55
That is (AFAIK) part of the m-sport package. Those lines run to a radiator behind the left (or right, I'm unsure) fog light grille.
      02-13-2020, 08:04 PM   #56
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Just ordered my Ebay strut! Will post some install pictures when I do. Anyone upgrade their sway bars and if so which one's?
      02-13-2020, 08:14 PM   #57
513
I did H&R front and rear and will get my strut bar anyday now.
Can someone comment on how this feels and if it has reduced body roll?
      02-14-2020, 04:16 AM   #58
John H.
John H.'s Avatar
Part# 11427573212
https://www.ecstuning.com/b-genuine-...t/11427573212/
You have a thermostat in that. Looks like someone was in there, aftermarket t-stat cover, BMS? A popular mod is to change the valve.
https://www.turnermotorsport.com/p-5...-e6061-n54n55/
      02-14-2020, 04:23 AM   #59
John H.
John H.'s Avatar
I did H&R front and rear and will get my strut bar anyway now.
Yes, the bars helped. Most noticeable improvement in my heavy front, transaxle and transfer case.
      02-14-2020, 11:27 AM   #60
513
Part# 11427573212
I do have the high flow valve from BMS also installed, it made a huge difference. My car runs very cool.
2011 F10 S55 6MT
      02-14-2020, 12:08 PM   #61
How many "wrenches" was the install?
      02-14-2020, 12:25 PM   #62
Unspec
Unspec's Avatar
1300
I think it's part of the driver's package (high speed synchronisation). At least according to realoem, but realoem could also be wrong. Says it's also part of the hot climate version (hot OR high speed), but my car does not have that style heat exchanger even though it's a hot climate version. I just have the block style heat exchanger.
2015 BMW 535xi
      02-14-2020, 12:45 PM   #63
My 2014 m-sport has the one with the plumbing and hot climate version (S823A) and my base (luxury?) 2012 has the block style; also with the hot climate version (S823A). The 2014 also has high speed synchronization (S840A) which is absent on the 2012.
      02-14-2020, 12:55 PM   #64
Unspec
Unspec's Avatar
1300
I'll double check my FA later when I get home (maybe the decoders are getting it wrong) but I'm pretty sure I have 823. I think your 2014 has it because of 840, not because of m sport.
Edit:
This thread would suggest it's not related to m sport at all:
https://f10.5post.com/forums/showthread.php?t=1399982
2015 BMW 535xi
      02-14-2020, 02:05 PM   #65
Edit:
Yeah... I thought only m sports had 840.
      02-14-2020, 05:58 PM   #66
513
It was super simple. Just make sure you have the correct sockets/torx etc and you are good to go.
2011 F10 S55 6MT
