2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 351m Wheels question
      09-12-2020, 05:58 PM   #1
Javi5
Javi5's Avatar
Drives: 2015 535i M-Sport
Had a quick question,
I recently purchased a set of used 351m wheels from CL. Oddly after I purchased I looked behind the wheels and they were all 8.5x19 with the same tires all around size 245/35/19. After doing research I noticed that the rears should be 9x19 and the front should be 8.5x19.
Is it safe to have the same tire size all around along with 8.5x19 wheel width? Did I get screwed?
2015 F10
M-Sport
      09-12-2020, 06:53 PM   #2
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
I recently purchased a set of used 351m wheels from CL. Oddly after I purchased I looked behind the wheels and they were all 8.5x19 with the same tires all around size 245/35/19. After doing research I noticed that the rears should be 9x19 and the front should be 8.5x19. LCI non-xDrive MSports did have the staggered setup as an option, but having a square setup is not a real problem.
2015 F10
M-Sport
Two things.
First - 4 x 8.5x19" 351M wheels are stock on MSport F10s, including non xDrive in the early F10 years. No problems there. They came with a 'square' setup from the factory. LCI MSport F10s did have a staggered setup as an option, but having a square setup is not a real problem.
Second - your tires sizes are wrong. Someone in the past has screwed them up. Stock tire size for the 8.5x19" 351M is 245/40/19. My xDrive came with that as standard equipment from the factory (wheels and tires as I've mentioned).
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      09-12-2020, 06:58 PM   #3
Javi5
Javi5's Avatar
2015 F10
M-Sport
Two things.
2015 F10
M-Sport
Two things.
Thanks for the response. Makes me feel so much better.
So what happens if I dont change these tires and leave them?
      09-12-2020, 07:45 PM   #4
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
It depends on where and how you drive. The '35' vice '40' means you have a thinner sidewall (by 13%), so on rough roads you have the real possibility of damaging a wheel. Those with 20" and 21" wheels face the same problem because their sidewalls are thinner too. The second thing is that your overall diameter is smaller than stock by 4%, so your speedometer will read 4% higher than stock, which is already higher than reality. It will also probably affect your odometer and you will rack up the miles just a little quicker.
Here is a wheel / tire calculator that helps show the differences.
Wheel Calculator
