2010 2011 BMW 5 Series Forum F10 anyone have experience with a setup like this |
11-01-2020, 07:50 PM | #3 |
Rep 697
Drives: 2013 535xi
Rear tire sizes should be 285/30/20 vice 285/35/20. Front tires are OK.
Regarding wheel offsets, the front wheels might work but the tire will be close to the fender. I think the rear wheels have too low an offset, so the tires might rub on your fender or even stick outside it. The wheel hub bore is also the wrong size. It should be 72.6mm. The wheels you've specified have a hub bore of 74.1mm. They will not be easy to centre properly on your car and will likely vibrate at speed.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) Last edited by cdmulders; 11-01-2020 at 08:47 PM.. |
11-02-2020, 01:19 PM | #4 |
Rep 2,591
Those rears will poke out like crazy. On my 10x20 ET34, the rim is already flush and the 295/30/20 tires poke a bit. The rears will sit out 12mm further, don't recommend.
Fronts are okay-ish. I have 9x20 ET34 on the front and it sits a bit tucked, so the extra 14mm should make it almost perfectly flush. As cdmulders said, that bore is too big.
2015 BMW 535xi
11-05-2020, 07:01 AM | #5 | |
Rep 108
11-05-2020, 07:04 AM | #6 | |
Rep 108
