2010 2011 BMW 5 Series Forum F10 brake pads changed and error codes |
11-12-2020, 08:00 PM | #1 |
Rep 97
searched anywhere on the internet that i need to reset it by pressing a button on the speedo but i dont see anything in there. does the sensor to be change everytime we change the pads?
11-13-2020, 01:16 AM | #3 |
Rep 97
11-13-2020, 10:10 AM | #4 | |
Rep 2,591
Rear sensor: 34356791962 The links are to the OE sensors. If you want BMW ones, just search for the P/N, they're the same. As for resetting, just google "how to reset brake interval bmw" or something.
2015 BMW 535xi
11-13-2020, 09:29 PM | #5 |
Rep 418
I did front and rear rotors and brake pad change recently, I've replaced the sensors and reset brakes change on the instrument cluster, watch this video for reset procedure
11-13-2020, 09:51 PM | #6 |
Rep 377
Drives: 16 X3 28d/18 540d xdrive
It might help to qualify the statement about sensors having to be replaced with pads. If pads are replaced before sensor contacts the rotor, then it can be reinstalled with the new pads. Correspondingly, the vehicle's brake monitor system can be reset without problem. Having changed front and rear OE pads on my X3 with ceramic ones, I retained the sensors and reset the brake warning system without an issue.
