2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Change wood trim to hexagonal aluminum
      09-14-2014, 09:39 AM   #1
TiresOnFire
TiresOnFire's Avatar
32
Drives: 2015435i,2015550i,2017M240i
Anyone have experience with what effort it will take to change out the trim in a 2015 550i?
Dealer mistake on European Delivery order (that was an unwelcome Munich surprise) and weighing having a new car built versus local retrofit.
I advised dealer in writing production order made no ref to hex and they wrote assurances it would be hex. Oops.
Thanks.
      09-14-2014, 10:30 AM   #2
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
It's pretty easy. I took out the center consol yesterday to polish out the scratches in the wood and it's a piece of cake. Is the dealer going to make you whole on the switch?
      09-14-2014, 10:58 AM   #3
TiresOnFire
32
Thanks Mbbrewer. How about the dash and door trims; just as easy? Yes, it's up to the dealer to fix this; it's all in writing, they assured me it would be hex trim despite my pointing out it wasn't mentioned on the production order (all in writing); they have no choice but to make it right. What I'm most worried about is whether I'll end up with a bunch of trim popping out of place, unfastened wires behind the dash, and odd noises. I would rather just have them order me a new car if there's any risk of it being any less than 100%.
      09-14-2014, 11:36 AM   #4
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
I see your point Bill. If they are willing to order you a new car, I would go that route. Would they be willing to give you a loaner while the new car is built?
      09-14-2014, 11:47 AM   #5
TiresOnFire
32
Thanks. That's what I'm thinking too; unless someone chimes in stating they've swapped all of the trim and it's all snap in easy. Loaner is no problem. I have three BMW's to drive. Now, whether the dealer will step up to flying me to Munich for another European delivery is the real question :-).
      09-14-2014, 01:53 PM   #6
PeterGriffin
Bayern Bier und Razierte Frauen
Sweden
14
Drives: Ordered X7 23 40d all options
Its a very easy job. I have changed from Alu fine to Anthracite wood.
I drive the car every day and use it alot. Nothing is making any sounds, popping out or anything. You will not notice any difference at all if they do everything correct.
So donīt worry, let them do the swap and try to make them compensate you instead =).
      09-14-2014, 02:28 PM   #7
TiresOnFire
32
Thanks PeterGriffin. Interesting. To be clear, you changed dash, doors, and console? Does it snap off / snap on? Must the entire dash be disassembled to get to fasteners within?
      09-14-2014, 02:46 PM   #8
PeterGriffin
Sweden
14
BillFuchs, Yes, I changed all of my trim.
If i remember correctly the ones in the doors you just pull them right of.
2 min for all for doors.
The fasteners are in the trim so its just to pull everything of, after you pull the dash trim of you unscrew the center vents and lights control. The fasteners are also in metal so nothing will brake are become loose.
For the center console its one unit with the ashtray etc. You just unscrew the i-drive controller from underneath when its loose.
Im not a mechanic, and im also not a diy:er. But this is really easy.
Don't worry, everything will be 100%. This is a really simple fix.
So just to be clear: Everything snaps on and off. You don't have to disassemble the dash. The fasteners are in the trim, there are holes in the dash and doorpanels.
      09-14-2014, 03:27 PM   #9
TiresOnFire
32
Thanks Peter. Your information is encouraging.
      09-15-2014, 03:08 AM   #10
qcocjnoralsm
Drives: bmw
