2010 2011 BMW 5 Series Forum F10 Genuine OEM BMW Borgwarner Turbo BMW F10 N55 |
11-08-2016, 07:02 PM | #1 |
Rep 1,214
These complete turbo charger unit was removed from my personal 3/2014 535i at 20,880 miles. It is a super clean take off unit, no rust, no corrosion, no oil consumption. Axial play on the shaft is within spec // as new. This has got to be the cleanest, lowest mileage, highest quality used turbo on available today. Again it was removed from a personal vehicle and it has an established vehicle history with the seller! Unit was removed to install a larger Pure Stage 2 turbocharger. This unit is priced belowwhat Pure's core charge is, so its a great way to save some money on a core charge up front, have no down time, and then flip your turbo afterwards... or as a direct install turbo to replace a higher mileage unit that is aging, burning oil etc. Waste gate actuator and bypass valve are not included. What is pictured is what you will receive. 11 65 7 583 908 TURBO CHARGER Part 11657583908 was found on the following vehicles: 5' F07 GT (09/2008 — 06/2013) 5' F07 GT LCI (08/2012 — 05/2016) 5' F10 (01/2009 — 06/2013) 5' F10 LCI (08/2012 — 05/2016) 5' F11 (02/2009 — 06/2013) 5' F11 LCI (02/2013 — 05/2016) 5' F18 (08/2009 — 07/2013) 6' F12 (10/2009 — 02/2015) 6' F13 (04/2010 — 02/2015) Matching low mileage catalyst is also available from the same car. It has several hundred less miles on it, and again is in impeccable condition. |
