2010 2011 BMW 5 Series Forum F10 BMW F10 2011 M Sport Coding Options |
09-03-2016, 06:51 PM | #1 |
Rep 17
To all the drivers of the above car.
What are your favourite coding options? I'll be getting my car coded tomorrow (map update as well) and wondered which options people have enabled/disabled in their cars? So far I have the below list:-
I wanted things like disable speed locks, enable fuel suggestions, splash logo to M sport, enable efficient dynamics, usb video playback to different codecs, m sport in cluster, wind shield wipers complete cycle, european blinking lights but was told they can't be done. Is that right? Would like suggestions on other options as well please? |
09-04-2016, 02:39 AM | #2 |
Rep 5,092
if you a HUD enable the indicators.
there is also the entertainment list displayed in the HUD but you will need a certian level of firmware for that to work.(has the firmware been upgraded on your car?) set ASS to off ( or last memory) taillights on with drl. do you have the extended instrument cluster? change the orange strips to be grey instead. if you google f10 cheat sheet you find a list of the possibilities although obviously some are dependent upon hardware. |
09-04-2016, 03:22 AM | #3 | |
Rep 17
I already have turn signals in the hud (when the Sat navigation is on) and songs list, saved radio stations. By cluster, do you mean pro sat nav? No I don't. Can I not get the codecs enabled so I can play any file from USB? |
newf100.00 |
09-04-2016, 03:54 AM | #4 |
Rep 5,092
when i say turn signals i dont mean satnav directions but turn indicators . left and right arrow that light and flash when you press the indicator stalk.
re codecs I dont know. only know of mp3, wma and wav files that can play. later hardware moght be able to others possibly - not sure. |
09-04-2016, 03:55 AM | #5 |
Rep 5,092
oh and by cluster i mean 6wb , the extended display where the lcd screen goes across the whole of the bottom of the instrument cluster tathan partially on the 6wa.
09-04-2016, 04:15 AM | #6 | |
Rep 17
09-12-2016, 08:04 AM | #9 | |
Rep 1,040
H izyounis,
I hope you don’t mind me asking! Was coding Enable Digital Speedo & Sports display when in sport mode easy, I also have a 2011 m sport 520d car! Thanks for your feedback. Quote:
09-12-2016, 08:36 AM | #10 | |
Rep 345
Enable Digital Speedometer On Cluster KOMBI => 3000 => BC_DIGITAL_V => aktiv Enable Sports Display HU_NBT or HU_CIC => 3000 HMI => EFF_DYN_SPORT_CID => aktiv HU_NBT or HU_CIC => 3000 HMI => EFF_DYN_SPORT_UNIT => aktiv
Current: 2013 F10
Previous: 2007 E90 Previous: 1994 E34 |
09-15-2016, 01:56 AM | #12 | |
Rep 1,040
Thanks ALPWhite, I need to make my mind up to code or upgrade the dials to 6WB, I guess with the 6WA dials the digital speedometer display is on the small side limited to the black panel!
ALPWhite137.50 |
09-24-2016, 06:57 AM | #13 |
Rep 581
09-25-2016, 11:42 AM | #15 |
Rep 581
10-07-2016, 05:10 AM | #18 |
Rep 84
I had mine remote coded in the end on my drive... I bought a cable and got the software but decided to sack it all off and get someone to do it via TeamViewer!
I had the following on my F10 LCI (with full black display): Stop start last setting | Rear DRL enabled | M animation idrive boot up screen | Digital speedo | Siri eyes enabled | Enhanced bluetooth | additional nav options enabled | dvd in motion | video via usb | xvid vcd ogg mp4 codec enabled | idrive speedlocks removed | all gearbox and software updates I wanted a few other bits like door LEDS on reverse, fogs on full beam and fogs on steering but these can only be coded if you have adaptive lighting and folding mirrors. The best option BY FAR is remembering the lat setting on the stop/start!
F10 LCI 530d - Full M Performance carbon fiber kit - Mineral Grey - H/K Stereo - Pro Nav - 20" 464M wheels
10-07-2016, 06:11 AM | #20 |
Rep 84
Have you cycled through the displays to see if it's been tagged on somewhere?
Tags |
coding 5 series, f10 |
