2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Car theft
      07-18-2012, 02:18 PM   #1
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Car theft
There's quite a lot of talk regarding the theft of BMWs in the UK. Car thieves are breaking the driver's side window to gain access to the OBD port in order to clone a blank key, which apparently takes little more than a few minutes to accomplish.
Does anyone know if this affects the F10/11 or whether it's limited to older cars which require the key to be inserted into the dashboard slot?
      07-19-2012, 02:05 AM   #2
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
I was told that it's not a problem on the F series cars but I'm not sure if that's accurate.
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      08-01-2012, 05:35 AM   #3
330cdsport
Right Responsible
330cdsport's Avatar
Drives: AW F21 M135i
I have been reading up about this too and am a bit concerned. I read somewhere that you can either lock the OBD port to stop physical access or disconnect it temporarily.
I tried removing the fuse for the OBD, but the car just went wonky after that - so it is not a solution.
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension
Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys.
      08-01-2012, 06:22 AM   #4
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Originally Posted by 330cdsport View Post
I have been reading up about this too and am a bit concerned...
There's a lot of discussion on this here: http://www.e90post.com/forums/showthread.php?t=725184
The OP is, I think, a policeman and, therefore, presumably privy to more info than us civilians; I've asked whether or not F10/11s are affected, but haven't yet received any answers.
      08-05-2012, 08:27 PM   #5
psyxologos
Drives: E46 330 ci SE, F11 530d SE
Sorry, noob question. What is the ODB port? A picture would help... Thanks!
      08-06-2012, 02:15 AM   #6
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
It's used to connect your car to a computer for diagnostics/reprogramming etc., and it's located below and forward of the small storage compartment under the light switch.
      08-07-2012, 05:26 PM   #7
psyxologos
Thanks. I had a look and could not see anything yesterday. I shall have another look tomorrow.
      08-07-2012, 08:17 PM   #8
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
It's just as easy to feel for it; slide your hand forwards under the dash below the light switch and you'll contact a protruding lip on the edge of the OBD port hinged cover. Flip it down to access the socket.
      08-08-2012, 03:03 AM   #9
gspannu
Drives: F10 535, F82 M4
A friend of mine does a protective plate for the OBD connector.
This is a made to order, fit to design yellow plate with screws. See picture attached. It is a customised fit to OBD cover plate shape hardened material plate specifically designed for this purpose.
You may (for additional security) use tamper proof screws as well.
Not a 100% proof solution; but it does prevent anyone getting easy access to the OBD port….
It is purposefully done in Striking Yellow to give it max visibility; as one of the key points of avoiding theft is to show the potential thief that you have some sort of protection mechanism - and thereby it is not worth his while to attempt theft on your car.
If you are interested in buying this; I can forward your request to my friend. PM me for details...
      08-08-2012, 03:15 AM   #10
xenon
xenon's Avatar
England
1397
Hmm, I'm pretty sure the blaggers would have a No. 2 Phillips and if you use tamperproof screws then the port is disabled for legitimate use. A proper software update is what's needed.
Ian
      08-08-2012, 05:11 AM   #11
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Originally Posted by xenon View Post
Hmm, I'm pretty sure the blaggers would have a No. 2 Phillips and if you use tamperproof screws then the port is disabled for ligitimate use. A proper software update is what's needed.
Quite agree and, regardless of the type of screw being used, seeing as they're only threaded into relatively soft plastic, I don't see the guard putting up much resistance to being wrenched off with a simple lever, such as a flat-blade screwdriver.
      08-08-2012, 07:28 AM   #12
psyxologos
Indeed!
      08-08-2012, 01:33 PM   #13
gspannu
@psyxologos, @Jon D, @xenon
As I said its not 100% fool proof, but it's not 'that simple' to just rip off the plate or unscrew the screws (or tamper proof)... The person trying to steal your car is trying to make this quick, with minimum fuss.
Most likely the potential thief has broken your window glass, and then slides his hand by the inside of the door to access the port and slot in his OBD cable. Opening screws with a screw driver/ ripping off a plate will require a lot more movement/ intrusion and the car alarm is likely to sound.
As I said, not a perfect solution... In fact I doubt there is any perfect solution. If your car is being stolen 'to order' then it's likely to be stolen regardless of what you do.
This is possibly a deterrent... It's better than not having anything at all.
      08-08-2012, 02:32 PM   #14
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Fair comment; apologies for my earlier cynicism.
      08-08-2012, 03:03 PM   #15
gspannu
No offence taken... I really did not read your post as cynical; you were just being straight...
On a side note; does anyone have any idea if BMW is responding with any solution?
      08-09-2012, 01:40 AM   #16
xenon
xenon's Avatar
England
1397
I still think that relocating the port as many on e90post have done is a better solution but I take your point. Hopefully pressure will be brought to bear on BMW who might issue some sort of fix but it might be the 1950s Pinto situation.....
Ian
      09-13-2012, 01:16 PM   #17
Mshulla
Drives: 520d MSport
There was a report on this last night on ch4 news. Seems the thiefs can get access to the OBD port without breaking the window
The whole thing is done in minutes, they showed it being done but obviously didn't show how they get an arm into the car without breaking the glass.
BMW apparently have a fix. I meant to call the dealer today but got bogged down at work, will try tomorrow.
      09-14-2012, 04:47 AM   #18
MalithS
Drives: BMW F10 LCI 530D Luxury
http://f10.5post.com/forums/showthre...1#post12678464
      09-14-2012, 08:25 AM   #19
XDEEDUBBX
XDEEDUBBX's Avatar
64
Drives: 535I
Does anyone actually use an "auto lock" on the brake pedal? I use one in my Toyota Tacoma.
      09-14-2012, 10:02 AM   #20
billythetidd
Drives: BMW 520d M-Sport
There was a thing about this on Watchdog the other night:
Linky
Apparently it only effects cars built between 2006 and 2011.
      09-14-2012, 11:36 AM   #21
330cdsport
Right Responsible
330cdsport's Avatar
http://www.whatcar.com/car-news/bmw-...cle4b_headline
I just booked the wife's X5 in to get the software fix next wednesday. The dealer told me that all F10/F11 cars are un-affected - so mine should be ok.
It will be a no-cost fix and should take about 30 mins.
      09-14-2012, 04:30 PM   #22
MalithS
When I called BMW UK this morning I was told my Sep 10 F10 was affected and BMW would contact me once the fix is available. I think all BMWs pre Sep 11 are affected.
