2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Harmonic Vibration Feel on my 2013' 528i
      03-01-2017, 03:51 PM   #1
cartechfreak
Drives: 13' Dark Graphite 528i
Question Harmonic Vibration Feel on my 2013' 528i
Guys,
Need your Help trying to find the root cause of an issue that is driving me nuts.
i have weird Harmonic Vibration when driving at highway speeds.
feel it mostly on the floor.
i have taken it to BMW showroom and Road force balanced all wheels Multiple times.
they even kept my car for a day and returned my car saying there is nothing much they can do.
is this kind of non continuous vibrations also signs of Bent RIM?
Appreciate your inputs.
PSK
      03-02-2017, 08:18 AM   #2
cartechfreak
Any one?
PSK
      03-02-2017, 12:48 PM   #3
snj1013
Drives: 2011 528i
What were the road force values for each tire/wheel assembly?
      03-02-2017, 01:08 PM   #4
Propshaft??? And if the F10 has a 2-piece propshaft the carrier bearing??
      03-29-2017, 05:42 AM   #5
Apples12
Drives: 520D LCI auto
Hi,
Did this get resolved?
I'm currently working with dealership to get this resolved on my car
      03-30-2017, 12:43 AM   #6
cartechfreak
Originally Posted by Apples12 View Post
Hi,
Nope...I'm planning to replace my wheels and see if it makes any difference.
PSK
      03-30-2017, 10:08 PM   #7
snj1013
Drives: 2011 528i
You never replied with the road force values! If you have any that are over 10 lbs, you will have vibrations around 70mph. Your SA may say different, and values in the 15-20 lb range may not cause issues with other vehicles, but with the F10 chassis, it will cause the problem you're describing.
      03-30-2017, 10:47 PM   #8
cartechfreak
Actually I don't have my road force values with me. may be next time I will ask my SA for those values.
So if they are more then 10 do you suggest replacing the wheel ?
By the way with damaged rim will the vibrations be harmonic?
PSK
      03-31-2017, 02:45 PM   #9
snj1013
Drives: 2011 528i
If you have excessive road force, the problem could be excessive run out from the wheel (wheel isn't perfectly round) or a defective/unevenly worn tire.
      03-31-2017, 11:45 PM   #10
top ramen
Drives: Schwarz II 535i
Was having the same issue with highway vibrations starting from 70 and above and snj1013/John was able to point me to the right direction. I could feel my vibration on the foot rest and into the seat. It was to the point where I could see the headrest on the passenger seat vibrate so slightly when the seat is not occupied. Did a true road force balance and getting it below 10lbs solved my issue. Try finding a good tire shop that know what they're doing.
      05-31-2017, 11:16 AM   #11
BMelchner
Drives: 2012 BMW 535i Xdrive MSport
Does it happen when turning? I had the same type of issue which turned out to be a wheel bearing. Vibration on left turns is left front. Vibration on right turns is right front. Opposite from what I know about all other cars.
Tags
harmonic vibration
