2010 2011 BMW 5 Series Forum F10 Oil Measurement Inactive -- F10 550i |
04-26-2019, 08:25 PM | #23 |
Rep 59
windowmaker70.00 EL Jeffe 5612.50 |
04-26-2019, 08:32 PM | #24 |
Rep 175
Lol it is confusing at first, but once you got the hang of it, this is quite a tool. I usually go there time to time to measure my water temps since all you have on board is your oil temp.
But this is irrelevant until you get the oil inactive problem solved, which we are hoping that it is just a simple oil level sensor. Not the costly dme......and only the dealer is able to provide. I tried numerous shops to write out a fix on the current dme.......no one is willing to touch it. Unless your car is a 2014 or above. |
04-26-2019, 08:34 PM | #25 | |
Rep 59
04-26-2019, 08:43 PM | #26 |
Rep 175
I highly understand that statement, especially since my father gave me a special gift from his origin of being a mechanic. He has worked on everything from small engines to cars and boats, then ultimately to aircrafts.
But all of which are old technology. Carburetors, points/condenser, couple of fuses and there you have it. He, too also have a hatred of newer cars with technology that doesn't make sense other than to use as an advantage to monetize from the common people. I took to another level of working on such which he asks me advice on newer cars which I am forever grateful since he is the one who started my whole knowledge of this field. My 2011 550i wouldn't make 116k miles today, while making 500hp and not burn a drop of oil and not needing to break the wallet if it wasn't for him. Sorry of getting carried away lol. Good luck, please report back with your findings. |
04-26-2019, 08:46 PM | #27 | |
Rep 59
04-27-2019, 04:33 PM | #34 |
Rep 175
Man....so many screw ups lol
Sorry, I was working all day and this forum doesn't update me on your posts. So the one picture with that bolt looks to be incorrect. Mines are Allen head ( hexagon head) so there's one screw up. Looks too long hence the loose feel. The other picture with the missing bolt is DEFINITELY an issue. That is indeed a ground point. You need to put an appropriate bolt there. The plug that was disconnected to the alternator is definitely part of your issue. Now....your oil sensor doesn't fix the issue. You got one more chance here before the big deal. Your alternator is possibly shot. I'd change out the alternator AFTER ALL BOLTS ARE SECURED. Get a used good one. A new alternator from autozone or discount wont work. The bsd wont communicate as I have heard from other places here. Next time, PM me so I can give you my number so I can respond quicker. Sorry about that. |
04-27-2019, 04:38 PM | #35 |
Rep 175
Also to anyone reading here or passing by, take notes.
Apparently that shop didnt do a good job or clueless of leaving a couple bolts missing that caused a potentially expensive repair. You can leave a bolt missing here and there on an old lawnmower but not on a car like this. I would put that shop on blast........respectfully though. |
04-27-2019, 05:02 PM | #37 |
Rep 175
Alternator is not working properly. It is not spiking up to 15.2 or so volts when you coast ( mpg on the blue side).
It is dead. Not charging properly, it is under basic charging. |
04-27-2019, 05:25 PM | #42 |
Rep 59
I went to my local BMW today. The tech just gave me the right ground bolts to use. They have been replaced. How many ground points are on the harness?
04-27-2019, 05:32 PM | #44 |
Rep 59
Here's an OEM alternator out of an X5 with the N63. Will that fit?
https://www.ebay.com/itm/Alternator-...C+Turbocharged |
