2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding "Base variant not determinable, check diagnostic address [G175]"
      06-03-2015, 03:01 PM   #1
AP
AP's Avatar
2777
Drives: G30 M550
I have Esys 3.24.3 on my win7 x64 laptop and am attempting to grab information in order to generate a FSC code for a sat nav map.
(I can't use swidreader as I don't have access to a 32 bit OS and this app is known not to work with x86 OS's)
As I haven't actually used this version of esys on my laptop yet It could well be have an issue , I am however just wondering if anyone has seen the following error message and if so what was done to fix it.
If not, then I'll look to reinstall at some point.
So I connect to the car (and confirm that I do)
So I log into FSC-Extended
Diagnostic address is 0x63
Base variant is HU_CIC
Application ID is 0x1b
Upgrade index is 0x1
When I click on Identify I get the error message "Base variant not determinable, check diagnostic address [G175]"
pretty sure those values are correct for 2012 model with CIC and upgrading for the 2015-2 European Premium.
Anyone seen this before by any chance?
if I get past this I should be able to generate the activation code.
      06-22-2015, 03:26 PM   #2
Xx 335Mangaki xX
Drives: 12 550xi
So... try this if you arent doing this laready,
1) Enter Diagnostic Address= 0x63
2) Click on the Identity button and the Base Variant should autofill
3) Application ID=0x1B
4) Upgrade Index= 0x1
Let me know how it goes.....
      06-23-2015, 05:35 AM   #3
AP
AP's Avatar
2777
Drives: G30 M550
Thanks,
Yes I've tried that already, in fact that's the first thing I tried. When I clicked on identify, I got the message. That's why I tried just manually typing in the value of HU_CIC.
Not sure what it might be other than something not being right with eye in some way.
Frustrating as the steps required to generate the file for the FSC code seem quite straight forward.
      06-23-2015, 12:20 PM   #4
Xx 335Mangaki xX
Drives: 12 550xi
Weird,, exactly it took me a a few to figure it out with the help of a couple of forum members but once completed, its an easy process.
      06-23-2015, 12:24 PM   #5
Xx 335Mangaki xX
Drives: 12 550xi
Sooo.... two things... I was using ESys 3.26.1 and i would double click o nthe Esys Premium shortcut. Does that make sense?
      06-23-2015, 12:32 PM   #6
AP
AP's Avatar
2777
Drives: G30 M550
i think its worth me getting hold of that version and trying again
thanks
